- This topic has 0 replies, 1 voice, and was last updated 10 months, 1 week ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX53U Firmware version 3.0.0.4.386_69142 ASUS RT-AX53U Firmware version 3.0.0.4.386_69142 Version 3.0.0.4.386_69142 2025/09/16 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment. Security Enhancements: – Password...
2025/09/16
System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
