- This topic has 0 replies, 1 voice, and was last updated 2 years, 2 months ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS Slow UI using HTTPS but not when Using HTTP Handy Tip: Sometimes after an Firmware upgrade the web UI can become slow an unresponsive, if this does happen and you are accessing the router via HTTPS, it maybe worth...
Handy Tip:
Sometimes after an Firmware upgrade the web UI can become slow an unresponsive, if this does happen and you are accessing the router via HTTPS, it maybe worth re-enabling HTTP (Local Access Config) and then see if routers UI is more responsive.
If the ASUS routers UI does become more responsive after enabling HTTP access, then the issue could be the need to add the router certificate to your trusted root certification authority. for your browser.
Chrome:Â https://superuser.com/a/632060/172416
