Converting DSL-AC68U to RT-AC68U for use as AiMesh Node – Solved I’m sure there were a series of posts on the old forum about hacking a DSL-AC68U to make it into an RT-AC68U. Sadly those posts are lost and not cached…
Viewing 15 posts - 1 through 15 (of 199 total)
  • #1873
    AvatarSix
    • Replies 55
    I’m sure there were a series of posts on the old forum about hacking a DSL-AC68U to make it into an RT-AC68U. Sadly those posts are lost and not cached on Google searches.
    I believe that RT firmware can be loaded using the recovery process. Does the standard Asus RT firmware work on the DSL or is a Merlin version needed.
    The aim is to use the DSL as an AiMesh node, hence the conversion to being an RT. I believe that after loading the RT firmware the DSL needs it’s ID changing. Does anyone have the commands needed to change the ID?
    Thanks in advance.
    #1874
    Enjoy ;) Either ASUSWRT or RMerlin firmware will work.
    Note: backup original config as this maybe needed to convert back to DSL-AC68U if needed.
    RMerlin (ASUSWRT-Merlin) Firmware and the ASUS DSL-AC68U (PPPoE)
    Regarding Product ID: 2 options both of which I have never tried, and if you try, at your risk ;-)
    1) Backup config from DSL-AC68U after it has been flashed. then via an hex editor, change router name to RT-AC1900, so new name has same number of character as original name and then load .cfg file to router and see if this does the trick ?
    OR
    2) Telnet to Flashed DSL-AC68U running RT Firmware (RMerlin is best and change variables  as appropriate below)
    Code:
    nvram set cfg_device_list=”<RT-AC68U>192.168.1.1>38:2C:4A:CA:D1:B8>0″
    nvram set dms_friendly_name=”RT-AC68U-D1B8″
    nvram set computer_name=”RT-AC68U-D1B8″
    nvram set productid=”RT-AC68U”
    nvram set lld2d_hostname=”RT-AC68U”
    nvram set asus_device_list=”<3>RT-AC68U>192.168.1.1>38:2C:4A:CA
    :D1:B8>0>asus>255.255.255.0>1″
    nvram set wps_modelnum=”RT-AC68U”
    nvram set daapd_friendly_name=”RT-AC68U-D1B8″
    nvram set wps_device_name=”RT-AC68U”
    nvram set odmpid=”RT-AC68U”
    Let us know how this goes and good luck?
    #1875
    AvatarSix
    • Replies 55
    Trying to post a guide to what I’ve done so far, keep hitting a xxxxx protection issue.
    This post edited by UK Sentinel (Admin) to remove security related detail
    #1876
    AvatarSix
    • Replies 55
    Thanks for the above, I found the same list of commands after a huge amount of digging elsewhere.
    Need to confirm that router can find the AiMesh Node later on (main router currently in use).
    Part One:
    Steps taken so far:
    Download and unzip latest RT-AC68U firmware from asus.com
    Download, unzip and install Recovery Tool from asus.com
    Factory resest DSL-AC68U
    Put DSL-AC68U into Recovery Mode by holding reset while powering on and waiting for flashing power LED.
    Connect to DSL-AC68U with ethernet cable and manually set IP to 192.168.1.10 and gateway to 192.168.1.1.
    Run Recovery Tool, browse to find RT firmware and upload.
    Wait for 5 – 10 mins.
    Reboot when instructed to.
    #1877
    AvatarSix
    • Replies 55
    Part Two:
    Connect to the router which at this point will still identify as DSL-AC68U despite running RT-AC68U firmware.
    Goto Administation>System and enable Telnet.
    Telnet onto the router.
    Enter:
    nvram show
    Select the output and cut and paste it into a text document as a backup.
    #1878
    AvatarSix
    • Replies 55
    Part Three:
    Find the entry for cfg_device_list and copy the MAC Address and replace in both instances of XX:XX:XX:XX:XX:XX below
    Replace XXXX with the last 4 digits of the Mac Address
    Enter:
    nvram set cfg_device_list=”<RT-AC68U>192.168.1.1>XX:XX:XX:XX:XX:XX>0″
    nvram set dms_friendly_name=”RT-AC68U-XXXX″
    nvram set computer_name=”RT-AC68U-XXXX″
    nvram set asus_device_list=”<3>RTAC68U>192.168.1.1>XX:XX:XX:XX:XX:XX>0>asus>255.255.255.0>1″
    nvram set daapd_friendly_name=”RT-AC68U-XXXX″
    nvram commit
    Then reboot your router, it should now identify as an RT-AC68U and allow you to select the option to use it as an AiMesh Node.
    #1879
    AvatarSix
    • Replies 55
    Guess it doesn’t like long posts.
    #1882
    [quote quote=1879]Guess it doesn’t like long posts.[/quote]
    Yes, xxxxx is a struggle sometimes (but designed to stop spammers inserting very long messages or sql injection type attack’s which I am plagued with at the moment from China and Ukraine), thanks for steps and hopefully all good your end ;-)
    #1886
    AvatarSix
    • Replies 55
    OK this is not working at present, trying to find out why the nvram set commands won’t survive the AiMesh enabling reboot.
    #1888
    [quote quote=1886]OK this is not working at present, trying to find out why the nvram set commands won’t survive the AiMesh enabling reboot.[/quote]
    Did you change the dms_friendly_name etc. to match you routers MAC Address last two octets ?
    Also, try ‘nvram+commit’  –  worth a try?
    #1891
    AvatarSix
    • Replies 55
    Yes I caught the dms_friendly_name change, just didn’t change it in the posts yet.
    nvram+commit?
    #1893
    [quote quote=1891]Yes I caught the dms_friendly_name change, just didn’t change it in the posts yet. nvram+commit?[/quote]
    Try ‘nvram+commit’ at the end rather than ‘nvram commit’ I noticed a few posts yesterday using this alternative?
    #1894
    AvatarSix
    • Replies 55
    Finally done it. Need to work through the steps before I can share.
    AiMesh set up and running nicely.
    #1895
    [quote quote=1894]Finally done it. Need to work through the steps before I can share. AiMesh set up and running nicely.[/quote]
    #1908
    I had a little play with my DSL-AC68U after flashing it with ASUS RT-AC68U Stock Firmware
    As above, I followed your steps 1 and 2 and then just entered the following commands via PUTTY (Telnet)
    nvram set asuscpeodmpid=”RT-AC68U”
    nvram set asuscpecommit=1
    nvram commit
    and hey presto, a DSL-AC68U that looks and acts as a True RT-AC68U with AiMesh (Node) option ;-)
    UPDATE: Command should be………….
    nvram set asuscfeodmpid=”RT-AC68U”
    nvram set asuscfecommit=1
    nvram commit
