What’s better – a wired or wireless mouse and keyboard? Wireless technology is typically billed as being a newer, cooler, more convenient alternative to our traditional plugged-in devices – but when it comes to buying computer mice and keyboards, is…
› UKTH forums › Computers › Monitors, Mouse & Keyboards › What’s better – a wired or wireless mouse and keyboard? Wireless technology is typically billed as being a newer, cooler, more convenient alternative to our traditional plugged-in devices – but when it comes to buying computer mice and keyboards, is...
  • #10669
    Wireless technology is typically billed as being a newer, cooler, more convenient alternative to our traditional plugged-in devices – but when it comes to buying computer mice and keyboards, is wireless always best? Let’s take a look at some of the pros and cons of both options.
    Pros of wireless mice and keyboards
    Freedom to move
    Most wireless/Bluetooth mice and keyboards can be used at a distance of up to 30ft (9m) of the transmitter, although at this distance you’re at risk of encountering lag and disturbance from obstacles. Still, the freedom to move further away makes wireless mice particularly useful for navigating through presentations, or collaborating on-screen with colleagues.
    Easier to travel with
    With a wireless keyboard or mouse, you don’t need to worry about coiling up your wires (only for them to unravel and tangle up in your laptop bag) when you’re on the go. You can leave the USB receiver plugged into your device so you can instantly resume work when you’re on the train, or out in a cafe – without having to scrabble around for USB ports on the side of your laptop.
    Reduces clutter
    If you’re a minimalist, you’ll love the way wireless keyboards and mice look clean and modern on your desk. You’ll enjoy a clear, neat space without any wires taking up valuable space, or getting caught up with your other belongings.
    Contributes to good workstation ergonomics
    The neater and clearer your desk is, the easier it will be to position your keyboard and mouse for comfortable alignment and posture. Make sure both your keyboard and mouse are as central to your body as possible – twisting or leaning to reach for them can contribute to aches, pains and injuries over time.
    Cons of wireless/Bluetooth mice and keyboard
    Slower and susceptible to interference
    Although rare, wireless and Bluetooth mice and keyboards can run into interference, or be slightly slower than their wired counterparts. While generally unnoticeable, this may be a no-no for gamers or anyone who requires absolute precision with their work.
    Can run out of charge
    Because they’re not plugged into a power source, wireless mice and keyboards inevitably require recharging. Generally battery life is impressively long, but that doesn’t completely eliminate the risk of being caught out and about with a dead mouse or keyboard.
    Replacement batteries
    If your mouse or keyboard is battery operated, you will need to keep replacing the batteries, which could be costly in the long run.
    Pros of wired mice and keyboard
    Reliable
    If you’re planning to take your mouse or keyboard out with you so you can work ergonomically on the go, you don’t want to suddenly run out of battery. Eliminate the risk entirely by opting for wired technology, which means your accessories will run off your laptop.
    Fast
    Because your wired mouse and keyboard are plugged directly into your laptop or computer, you don’t have to worry about lag or interference.
    Lower price
    If you’re looking for a low-cost option, you can often find wired mice and keyboards for less than wireless versions.
    Secure
    Some employers question the security of wireless connections; to eliminate all risk, opt for wired and plug your devices directly into your laptop or computer.
    Cons of wired mice and keyboardNot as tidy
    Having wires all over your desk can spoil the neat aesthetic and even cause you to have to lean or twist to reach various objects. If you do opt for wired, try to keep your wires untangled to avoid damage.
    More hassle to carry around
    Wires add bulk and weight – especially if you’re trying to travel light. They can also get tangled up with other items in your bag, making it more of a hassle to retrieve in public places like trains and cafes.
    Have to plug in
    Having a wired mouse and keyboard means that, if you’re on the go, you have to keep plugging and unplugging the USB connection whenever you stop and start work. While not exactly a deal-breaker, if you’re after convenience then wireless is the way to go.
    In conclusion, there’s a solid case for opting for both wired and wireless mice and keyboards. If you’re on the go a lot or like to keep a minimalist workstation, wireless may be for you. If you’re a gamer, a designer, or anyone else who needs precision and reliability, then opt for wired.
    Source: https://www.posturite.co.uk/blog/whats-better-wired-wireless-mouse-keyboard
