ASUS RT-AX82U – Official Thread
UKTH forums 🛜 Wireless Routers & Modems 💬 ASUS & Wireless ASUS RT-AX82U – Official Thread
Viewing 9 posts - 1 through 9 (of 9 total)
  • #28124
    • Replies 8,241
    Latest ASUS RT-AX82U Firmware version 3.0.0.4.388_24231
    Version 3.0.0.4.388_24231
    2023/11/16
    Bug Fixes and Enhancements
    – Fixed v6plus related Issues.
    – Fixed ipv6 network service filter not work.
    – Resolved OpenVPN Server TAP mode issue.
    – Fixed the problem that the AiCloud app cannot add router on Android 9.
    – Ensured consistent display of client status on the WireGuard server.
    – Enhanced system stability when accessing the WireGuard Server with DMZ enabled.
    – Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    Security Fixes
    – Fixed several curl vulnerabilities.
    – Fixed FFmpeg vulnerabilities.
    – Corrected an OpenVPN vulnerability categorized as CWE-134.
    – Strengthened protection against SSH brute force attacks.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax82u/helpdesk_bios?model2Name=RT-AX82U
    #31421
    • Replies 8,241
    New ASUS RT-AX82U Firmware version 3.0.0.4.388_24232
    Version 3.0.0.4.388_24232
    2024/03/06
    – Resolved guest network connectivity issues on AiMesh nodes by disabling guest network internal access.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax82u/helpdesk_bios?model2Name=RT-AX82U
    #33013
    • Replies 8,241
    Latest ASUS RT-AX82U Firmware version 3.0.0.4.388_24963
    Version 3.0.0.4.388_24963
    2024/07/26
    Bug Fixes and Enhancements:
    – Improved AiMesh system stability for more reliable connections.
    – Fixed UI bugs in AiMesh topology.
    – Resolved issues with AiMesh nodes using Ethernet backhaul for consistent performance.
    – Addressed v6plus-related issues to ensure seamless connectivity.
    – Corrected a display issue in the OpenVPN server that prevented IPv6 settings from showing correctly.
    – Enhanced LAN IPv6 DNS server validation for better network reliabilitys.
    – Fixed GUI icons and setup-related issues for an improved user experience.
    – Resolved a GUI bug that occurred when adding port range rules in the Network Service Filter.
    – Added DS-Lite Support.
    – Fixed USB function related issues.
    – Improved stability and consistent display of client status on the WireGuard server.
    – Resolved WAN connection issues for a stable internet connection.
    Security Updates:
    – Applied patches for CVE-2023-5678 & CVE-2024-0727.
    – Enhanced security in OpenVPN Custom Configuration for(CVE-2024-0401).
    – Addressed CVE-2023-48795 by updating the dropbear SSH server.
    – Updated StrongSwan to version 5.9.13 to address CVE-2023-41913.
    – Resolved CVE-2020-13848 by updating libupnp to version 1.3.1.
    – Fixed OpenSSL and command injection vulnerabilities.
    – Upgraded to the latest dropbear version.
    – Fixed a stack overflow vulnerability.
    – Fixed XSS potentially via malformed hostname in DHCP request.
    – Fixed vulnerability in command injection after authentication.
    #34414
    • Replies 8,241
    New ASUS RT-AX82U Firmware version 3.0.0.4.388_25004
    Version 3.0.0.4.388_25004
    2024/10/09
    1.Optimized memory management mechanisms, improving system efficiency and stability.
    2.Strengthened input validation and data processing workflows, further protecting your information security.
    3.Improved web rendering engine, enhancing browsing experience and security.
    4.Enhanced security of system command processing to guard against potential malicious operations.
    5.Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    #34935
    Avatarcitylightwalrus
    • Replies 55
    ASUS RT-AX82U Firmware version 3.0.0.4.388_25017
    Version 3.0.0.4.388_25017
    98.27 MB
    2024/11/18
    SHA256: 18ecb24ce88b32230949b711cc169993ca70b9d1e6c00ae87d4d59a0f1b28069
    https://www.asus.com/gr-en/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax82u/helpdesk_bios?model2Name=RT-AX82U
    • Replies 8,241
    #35734
    • Replies 8,241
    Latest ASUS RT-AX82U Firmware version 3.0.0.4.388_25029
    2025/02/25
    1.Enhanced input parameter handling techniques to improve data processing stability and system security.
    2.Enhance system access control mechanisms.
    #37771
    • Replies 8,241
    ASUS RT-AX82U Firmware version 3.0.0.4.388_25035
    2025/05/14
    • Improved compatibility with certain IoT devices.
    #39955
    • Replies 8,241
    ASUS RT-AX82U Firmware version 3.0.0.4.388_25098
    2025/10/28
    – Enhanced system stability.
    – Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
    – Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection
