› UKTH forums › 🛜 Wireless Routers & Modems › 💬 ASUS & Wireless › ASUS RT-BE86U – Official Thread
- This topic has 5 replies, 1 voice, and was last updated 2 hours, 30 minutes ago by  UK Sentinel. UK Sentinel.
- October 20, 2024 at 2:00 pm #34581New ASUS RT-BE86U Firmware version 3.0.0.6.102_37022 Firmware version 3.0.0.6.102_37022 2024/10/17 Security:
 1.Strengthened system code execution processes.
 2.Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
 3.Refined input validation in the web interface, ensuring a more secure web interaction environment.
 4.Improved data export functionality in the admin portal, ensuring accurate and secure handling of client information.
 5.Optimized memory management mechanisms, improving system stability.
 6.Improved system buffer management, ensuring reliable data processing workflows.
 7.Enhanced stack buffer management, promoting greater system stability.Bug Fixes:
 1. Improved AiMesh stability.
 2. Fixed IPv6 related issues.
 3. Fixed GUI bugs.
 4. Fixed VLAN trunk port not working properly.
 5. Fixed guest network pro related issues.In a completely sane world, madness is the only freedom (J.G.Ballard). You need to login in order to vote November 25, 2024 at 8:09 am #34976Latest ASUS RT-BE86U Firmware Version 3.0.0.6.102_37174 65.76 MB Firmware Version 3.0.0.6.102_37174 2025/02/19 1. Strengthened input validation and data processing workflows to further protect information security.
 6. Strengthened certificate protection, providing enhanced data security.In a completely sane world, madness is the only freedom (J.G.Ballard). You need to login in order to vote February 20, 2025 at 7:53 am #35656New ASUS RT-BE86U Firmware version 3.0.0.6.102_37812 Version 3.0.0.6.102_37812 2025/02/19 Security:
 1.Enhancing system security and user authentication processes
 2.Enhancing database/storage securityBug Fixes and Enhancements:
 1. Enhanced Client Connection Stability.
 2. WPA Encryption Settings Update. Added new configuration options for WPA encryption, including the option to select AES for improved client compatibility. This setting can be found under “Network > Main Network”.
 3. Improved AiMesh Backhaul Compatibility.In a completely sane world, madness is the only freedom (J.G.Ballard). You need to login in order to vote May 1, 2025 at 8:20 am #37358Latest ASUS RT-BE86U Firmware version 3.0.0.6.102_37841 version 3.0.0.6.102_37841 2025/04/30 Bug Fixes and Enhancements:
 1. Improved compatibility with IoT devices on WPA2/WPA3 networks.
 2. Enhanced the stability of remote connections.
 3. Resolved an issue with the WiFi scheduler.
 4. Improved Parental Control scheduling with support for SDN clients.
 5. Fixed an issue causing Movistar IPTV to malfunction.Security fixes:
 1. Implemented a security patch to address an OpenVPN issue.In a completely sane world, madness is the only freedom (J.G.Ballard). You need to login in order to vote August 12, 2025 at 1:09 pm #39049ASUS RT-BE86U Firmware version 3.0.0.6.102_38984 version 3.0.0.6.102_38984 2025/08/11 Important: After installing this firmware, we strongly recommend performing a factory-default reset to activate every new security adjustment. Security Enhancements
 – Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
 – Detailed Audit Trails – Expanded logging within the authentication module.System Improvements
 – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.Bug Fixes:
 – Fixed abnormal client list.
 – Fixed abnormal GUI behavior of Wireguard VPN.
 – Fixed USB internet backup conflict with main WAN.
 – Fixed abnormal WAN detection while AiDetection is enabled.
 – Improved AdGuard DNS GUI issues.
 – Fixed IPv6 related issues.
 – Improved USB tether compatibility for pixel phones.In a completely sane world, madness is the only freedom (J.G.Ballard). You need to login in order to vote October 30, 2025 at 7:32 pm #39960ASUS RT-BE86U Firmware version 3.0.0.6.102_39112 2025/10/29 – Enhanced system stability
 – Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
 – Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.In a completely sane world, madness is the only freedom (J.G.Ballard). You need to login in order to vote
