ASUS Time Zone – UK Clocks Go Back (British Summer Time)
UKTH forums 🛜 Wireless Routers & Modems 💬 ASUS & Wireless ASUS Time Zone – UK Clocks Go Back (British Summer Time)
  • #4864
    • Replies 8,252
    Just a reminder that as the UK heads towards the end of British Summer time, the clocks go back this Sunday by 1 hour (27th)
    Usually on ASUS routers, when you select Administration > System > and set Time Zone to (GMT) Dublin, Edingburgh, Lisbon and London, The DST Time Change Ends needs to be changed from the 2nd Sunday to the 4th, the Month (10th) stays the same (obviously)
    I have not worked out what DST Time Change Starts parameters are (problem for next year) so attachment maybe incorrect for ‘DST Time Change Starts’
    Edit: Clocks go forward on the 29th March 2020, so that is 5th Sunday
    #4892
    • Replies 997
    You have to set 5th sunday March 2 hour (will jump at 2AM to 3AM) and back on 5th sunday October 3 hour (will jump back at 3AM summertime to 2AM wintertime).
    Thats true as long as you have summertime in GB or anywhere in EU.
    5th is programmed as last sunday, so true for years with only 4 sundays in this month too.
    And hour is very misleading (at least for me), it’s not how many hours difference to anything but just the time when it will jump from one to the other, usually done between 2 and 3 AM in the morning.
