ASUS GS-BE18000 Firmware version 3.0.0.6.102_38818 (2025/09/18)
UKTH forums 🛜 Wireless Routers & Modems 💬 ASUS & Wireless ASUS GS-BE18000 Firmware version 3.0.0.6.102_38818 (2025/09/18)
RELEASE
  • #39729
    • Replies 8,178
    2025/09/18
    Security Enhancements:
    System Improvements:
    – AFC Channel Priority – Raised the selection priority to increase the likelihood of switching to Standard Power mode.
    – AFC Positioning Data Handling – Resolved an error where invalid location inputs blocked AFC activation.
    – AFC Retry Logic – Adjusted retry behavior to avoid interference with normal AFC operations.
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.
    https://rog.asus.com/uk/networking/rog-strix-gs-be18000/helpdesk_bios/
