ASUS RT-AX58U– Official Thread
UKTH forums 🛜 Wireless Routers & Modems 💬 ASUS & Wireless ASUS RT-AX58U– Official Thread
  • #22437
    Moderator
    • Replies 7,938
    New ASUS RT-AX58U Firmware version 3.0.0.4.388.22237
    2023/01/11
    1. Supported WireGuard VPN server and client.
    7. Fixed USB icon issue in port status.
    8. Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    9. Fixed status page HTML vulnerability. Thanks to David Ward.
    10. Fixed CVE-2018-1160. Thanks to Steven Sroba.
    11. Fixed cfg_server security issue.
    #25283
    Moderator
    • Replies 7,938
    New ASUS RT-AX58U Firmware version 3.0.0.4.388_23556​
    2023/06/20
    Bug Fixes and Enhancements
    – NowTV profile has been added under new IPTV profiles.
    – IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
    – Fixed a GUI bug that occurred when adding port range rules in the Network Service Filter.
    Security Fixes
    – Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
    – Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
    – Corrected an OpenVPN vulnerability categorized as CWE-134.
    – Fixed the Hostap vulnerability CVE-2019-10064.
    – Patched a command injection vulnerability to improve overall security.
    – Strengthened protection against SSH brute force attacks.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax58u/helpdesk_bios/?model2Name=RT-AX58U
    #31903
    Moderator
    • Replies 7,938
    Latest ASUS RT-AX58U Firmware version 3.0.0.4.388_24762
    Version 3.0.0.4.388_24762
    2024/04/12
    – Improved AiMesh backhaul stability.
    – Resolved the issue with login and password changes.
    – Enabled WireGuard Server clients to access the Samba server.
    – Enabled the failback function when using the iOS/Android USB backup WAN.
    – Improved Wireguard performance.
    – Enabled DynDNS and No-IP DDNS to use IPv6.
    – Improved memory utilization and fixed an occasional server error when registering DDNS with an app.
    – Modified the USB application option text in dual WAN.
    – Added DS-Lite Support.
    – Fixed ipv6 network service filter issues
    – Fixed the IPsec VPN compatibility issue with Win10.
    – Fixed the reboot issue when assigning specific clients in VPN fusion.
    – Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
    – Resolved the IPSec VPN and Instant Guard connection issues.
    Security updates:
    – Enabled and supported ECDSA certificates for Let’s Encrypt.
    – Enhanced protection for credentials.
    – Enhanced protection for OTA firmware updates.
    – Enhanced protection against SSH brute force attacks.
    – Fixed several curl vulnerabilities.
    – Fixed command injection vulnerability.
    – Fixed the ARP poisoning vulnerability.
    – Fixed code execution in custom OVPN.
    – Fixed the injection vulnerability in AiCloud.
    – Fixed stack buffer overflow in lighttpd.
    – Fixed CVE-2023-35720
    – Fixed the code execution vulnerability in AiCloud.
    – Fixed the XSS and Self-reflected HTML injection vulnerability.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax58u/helpdesk_bios?model2Name=RT-AX58U
    #34239
    Moderator
    • Replies 7,938
    New ASUS RT-AX58U Firmware version 3.0.0.4.388_25127
    Version 3.0.0.4.388_25127
    2024/09/30
    1. Optimized memory management mechanisms, improving system efficiency and stability.
    5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    #34809
    Moderator
    • Replies 7,938
    Latest ASUS RT-AX58U Firmware Version 3.0.0.4.388_25139
    2024/11/07
    Changelog:
    #36030
    Moderator
    • Replies 7,938
    ASUS RT-AX58U Firmware version 3.0.0.4.388_25155
    2025/03/17
    4. Enhance system access control mechanisms.
    #37822
    Moderator
    • Replies 7,938
    ASUS RT-AX58U Firmware version 3.0.0.4.388_25210
    2025/05/19
    • Optimized the app’s remote access capabilities for a smoother and more reliable connection.
    • Improved compatibility with certain IoT devices.
💫 UKTechHub
Privacy Overview
This Forum uses cookies so that we can provide you with the best user experience possible. Cookie information is stored in your browser and performs functions such as recognising you when you return to our Site and helping our team to understand which sections of the website you find most interesting and useful.
Privacy Policy
