› UKTH forums › 🛜 Wireless Routers & Modems › 💬 ASUS & Wireless › ASUS TUF-AX6000 – Official Thread
- This topic has 19 replies, 4 voices, and was last updated 16 hours, 31 minutes ago by
- November 5, 2023 at 9:44 pm #27885
New ASUS TUF-AX6000 Firmware version 3.0.0.4.388_32432
Version 3.0.0.4.388_32432
2023/08/16
Bug Fixes and Enhancements:
1.Added OCN(Open Computer Network) Support .
2.Updated the IPTV settings to ensure improved compatibility with Singtel-Others MIO TV and unifi_biz_voip / KPN services.
3.Resolved the issue where the network service filter was not functioning correctly for IPv6 connections.
4.Addressed the connectivity problem that occurred when clients connected to the guest network of an AiMesh node.
5.Fixed various issues related to v6plus functionality.
6.Addressed GUI bugs that were affecting the search process for AiMesh nodes.
7.Resolved issues related to USB functions for improved performance.Security Fixes:
1.Allowed binding DDNS to a user’s account to reduce the risk of MITM attacks.
2.Fixed CVE-2023-34359,CVE-2023-34358 Unauthenticated Denial of Service.
3.Fixed CVE-2023-34360 Stored XSS.
4.Fixed lighttpd vulnerability, CVE-2023-35720.
5.Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
6.Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
7.Fixed openssl vulnerability, CVE-2023-0464.
8.Fixed ReadyMedia vulnerability, CVE-2020-28926.
9.Fixed UPnP vulnerability, CVE-2020-12695.
10.Patched a command injection vulnerability to improve overall security.
11.Strengthened protection against SSH brute force attacks.
12.Fixed the cfg server vulnerability (Repeated in the same list).
13.Fixed the vulnerability in the logmessage function (Repeated without CVE number).
14.Fixed CVE-2022-46871.
15.Fixed Client DOM Stored XSS.In a completely sane world, madness is the only freedom (J.G.Ballard).
January 28, 2024 at 2:24 pm #30308Hi I recently updated my firmware manually to this version on Tuf ax6000
Firmware Version:3.0.0.4.388_33144
Funny thing though I can’t seem to find it again on asus website
January 28, 2024 at 2:43 pm #30310Welcome, that is interesting as I have just also looked and 3.0.0.4.388_33144 for the ASUS TUF AX6000 is not available.
I know ASUS RT-AX59U had a recent firmware release RT-AX59U Version 3.0.0.4.388_33144 which they (ASUS) have withdrawn due to issues with Apple Devices, so I assume the same for the TUF AX6000.
if you use apple devices, might be worth going back to your previous firmware release
February 24, 2024 at 9:05 pm #30892- Firmware seems to be back on asus site
ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33144Version 3.0.0.4.388_3314440.88 MB2024/02/22Resolved IPTV interruptions during extended use.
– Addressed Guest Network performance issues with active IPTV.
– Fixed potential Aura RGB crash.
– Added Xtra Range 2.0 support for enhanced connectivity.
– Rectified potential IPV6-related crashes.
– Improved roaming efficiency for AiMesh nodes under weak signals.
– Addressed router crashes during WireGuard setup.
– Fixed abnormal activation status in the Gear Accelerator function UI.Please unzip the firmware file, and then verify the checksum.
SHA256: 0728e5de8803383b5a7f55b01821b8ddddc68bc683164eabceb66bc79968ddc0-
This reply was modified 1 year, 7 months ago by
Irfand.
February 24, 2024 at 9:25 pm #30894Great news, no mention of Apple devices and issues in change log, so will be interesting to see how well this firmware release works
March 11, 2024 at 7:56 pm #31359ASUS TUF-AX6000 韌體版本 3.0.0.4.388_33147
Version 3.0.0.4.388.33147
40.87 MB
2024/03/11
Added eXtra Long Range support for enhanced connectivity.
MD5:51ba8a7c9a0f56aa5e292d9f630426c
March 11, 2024 at 8:41 pm #31360Great news
May 7, 2024 at 8:17 am #32130ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33404
Version 3.0.0.4.388_33404
41.03 MB
2024/05/02Bug Fixes and Enhancements:
– Enhanced AiMesh Stability
– Fixed an issue where the RE product ID was not being updated in the AiMesh topology.
– Added DS-Lite Support.
– Corrected a display issue in the OpenVPN server that prevented IPv6 settings from showing correctly.
– Fixed a persistent GUI issue on ‘Let’s Encrypt Authorization’ that displayed ‘Authorization’ incorrectly.
– Resolved a bug that prevented offline devices from being deleted in the Router App.
– Fixed an issue where the system would reboot due to parental control rules with empty enable fields.Security updates:
– Addressed CVE-2023-48795 by updating the dropbear SSH server.
– Applied patches for CVE-2023-5678 & CVE-2024-0727 from the Ubuntu Repository.
– Improved security in OpenVPN custom configuration.-
This reply was modified 1 year, 4 months ago by
citylightwalrus.
May 7, 2024 at 10:18 am #32135Welcome and thanks for the new Firmware release news
May 31, 2024 at 9:26 pm #32395ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33405
Version 3.0.0.4.388_33405
41.03 MB
2024/05/28– Resolved an issue where the Traffic Analyzer feature was not functioning properly.
June 1, 2024 at 5:30 am #32396And again, good to see new firmware for the ASUS TUF-AX6000,
Have you tried this new firmware yet ?
June 1, 2024 at 5:48 pm #32399Unfortunately, this router isn’t widely available in Canada. I’ve been eyeing on the TUF-AX4200 instead since it regularly goes on sale here, but I still debating if I want to lose out on Asuswrt-Merlin support (due to Mediatek chipset).
June 1, 2024 at 6:09 pm #32400Loss of ASUSWRT-Merlin is a big choice, luckily the TUF-AX4200 does have OpenWrt support if that helps
FYI.
https://openwrt.org/toh/asus/tuf-ax4200
June 5, 2024 at 1:35 pm #32436TUF-AX6000 also has OpenWRT support but definitely look at the TUF-AX4200 (imo OpenWRT > Merlin). You can also look at the RT-AX59U. It has identical hardware to the TUF-AX4200 but only has 1 Gbps ports.
July 23, 2024 at 4:20 am #32868ASUS TUF-AX6000 Firmware version 3.0.0.4.388_33411
Version 3.0.0.4.388_33411
41.04 MB
2024/07/22– Improved AiMesh reliability for a more stable connection.
– Applied patch for CVE-2023-41913 and CVE-2020-13848.Had to switch to the ASUS global site since the UK site wouldn’t show firmware page properly.
This reply was modified 1 year, 2 months ago by
citylightwalrus.
