AVM FRITZ!Box 7690 – Official Thread
UKTH forums 🛜 Wireless Routers & Modems 💬 AVM & Wireless AVM FRITZ!Box 7690 – Official Thread
  • #32466
    • Replies 8,177
    The new FRITZ!Box 7690 follows the FRITZ!Box 7590, and supports Wi-Fi 7.
    Technical specifications
    Interfaces
    • 1 x DSL connection, supports VDSL (including supervectoring and ADSL2+)
    • 1 x 2.5 gigabit WAN/LAN port, can also be used as a 2.5 gigabit LAN port (IEEE 802.3bz standard, NBASE-T)
    • 1 x 2.5 gigabit LAN port (IEEE 802.3bz standard, NBASE-T)
    • 2 x gigabit LAN (10/100/1000BASE-T)
    • Wi-Fi 7 on 2.4 and 5 GHz
    • USB 2.0 port for storage media and dongles
    • DECT base station for up to six handsets
    • 2 x a/b ports (RJ11) for connecting analog phones, answering ma
    DSL / Network
    • Wireless router with built-in modem for DSL connections
    • Supports VDSL connections up to 300 Mbit/s (including supervectoring) and ADSL2+
    • Supports VDSL Long Reach
    • Compatible with Deutsche Telekom Annex-J lines
    • Use of existing internet connections via LAN
    • Router operation with a cable modem, fiber optic connection or 3G data dongle (LTE/UMTS/HSPA)
    • Powerful processor: networked applications such as IPTV, video on demand and music streaming
    • Stateful Packet Inspection Firewall with port sharing for secure surfing
    • NAT, DHCP server, DynDNS client, UPnP AV
    • Supports IPv6 for internet, home network and telephony
    • Secure remote access, LAN-to-LAN linkup and dial-in to the company network with VPN (WireGuard and IPSec)
    • Parental controls with time budgeting, youth protection module
    • Security wizard with diagnostic tool
    • Wake on LAN via the internet
    • LEDs can be dimmed manually or based on room brightness
    Wi-Fi
    • 4×4 Wi-Fi 7
    • Wi-Fi 7 at up to 5760 Mbit/s (5 GHz) and 1440 Mbit/s (2.4 GHz)
    • Compatible with the IEEE 802.11a/g/n/ac/ax/be wireless standards
    • Extend your home network with Mesh Wi-Fi via a LAN connection – simply combine two or more wireless access points into one intelligent system.
    • Wi-Fi network encryption with WPA3/WPA2
    • AVM Stick & Surf: Browse the internet securely and without any cables
    • Wi-Fi can be turned on/off via “WLAN” button and/or connected telephones
    • Wi-Fi Protected Setup (WPS)
    • Wi-Fi guest access – secure surfing for friends and visitors
    • Wi-Fi auto channel: Automated search for an interference-free Wi-Fi channel
    • Wi-Fi eco mode for optimum performance at minimum power c
    Read more…
    https://en.avm.de/products/fritzbox/fritzbox-7690/
    #33695
    • Replies 8,177
    The FRITZ!Box 7690 will be available from 3 June (in Germany) for 329 euros (RRP) and the FRITZ!Box 5690 Pro will be available in stores (in Germany) in June for 369 euros (RRP).
    https://en.avm.de/about-avm/press/press-releases/2024/06/june-brings-new-fritzbox-power-for-fiber-optic-and-dsl-connections-with-wi-fi-7-to-customers-in-germany/
    Unsure if there is going to be an international versions ?
    #34576
    • Replies 8,177
    Product:	FRITZ!Box 7690
    Version:        FRITZ!OS 7.62
    Language:       Dutch, English, French, German, Italian, Polish, Spanish
    Release date:   27/08/2024
    **New features:**
    - - provider specific enhancements
    https://download.avm.de/fritzbox/fritzbox-7690/
    #35571
    • Replies 8,177
    Version: FRITZ!OS 8.02
    Release date: 16/01/2025
    # Top functions of FRITZ!OS
    – **TOP** User interface: Diagram showing the connections in the overview (homepage)
    – **TOP** New graphic Online Monitor informs about the utilization of the internet connection and on the utilization by individual network devices
    – **TOP** Internet: IPv6 data now can also be transferred via a WireGuard® VPN tunnel
    – **TOP** Mesh: Graph in new design with additional functions
    – **TOP** Push service: Reworked design and more convenience
    – **TOP** DECT: The number of DECT telephone calls possible concurrently was increased from three to five.
