Help with Fritz box 3490
  • #27451
    AvatarGoodMornang
    • Replies 4
    I am trying to connect my Xbox 360 to my fritz box 3490. I have port forwarded all the relevant ports but under port sharing and then under independent port sharing I have it enabled but it says 0 enabled. How do I get it to change from 0 enabled?
    • Replies 8,177
    Welcome, Firstly try and disable the option “Teredo filter enabled”.
    If this does not help then for testing purposes, remove all your Port forwarding rules.
    Then fix/assign (I forget the term) for the IP address of the Xbox, then enable  ‘automatic port sharing’.
    This should at least show whether you Xbox is getting OPEN NAT and the Fritz!box 3490 is working as it should be ?
    I used to use this option, especially when contingency multiple Xbox s.
    #27460
    AvatarGoodMornang
    • Replies 4
    Do you know where automatic port sharing is? I can’t seem to find it anywhere.
    • Replies 8,177
    My Fritz!Box is offline, but settings are as below and just add your Xbox (device) for sharing and then click apply.
    #27465
    AvatarGoodMornang
    • Replies 4
    For some reason, my Xbox 360 is working now with the ports open but it still only says 1 enabled and I have 6 in total. Don’t know why but it is connecting now.
    • Replies 8,177
    Is NAT type OPEN ?
    Port 3074 is the main one, the others help with chat etc, from what I can recall
    #27467
    AvatarGoodMornang
    • Replies 4
    yeah 3074 is open.
    • Replies 8,177
    Glad you seem to be all sorted, only way to really tell is use the Xbox for a few days and make sure it works as you think it should
