› UKTH forums › 🛜 Wireless Routers & Modems › 💬 ASUS & Wireless › ROG Rapture GT-BE98 – Official Thread
- This topic has 20 replies, 2 voices, and was last updated 1 week, 4 days ago by
- November 23, 2023 at 3:15 pm #28179
ASUS GT-BE98 Firmware version 3.0.0.6.102_32745
Version 3.0.0.6.102_32745
2023/11/21
This is the Initial firmware release for the ROG Rapture GT-BE98
https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
November 23, 2023 at 3:20 pm #28180According to Techinfodepot – hardware specs as below.
Rog Rapture GT-BE98 Hardware Specs
CPU1 Broadcom BCM4916
CPU1 Speed 2.6 GHz ( 4 cores )
Flash1 Size 256 MiB (NAND)
RAM1 Size 2 GiB (DDR4)
Ethernet Port Count 1-10GbE x 1-1GbE-WAN
1-10GbE x 3-1GbE-LANhttp://en.techinfodepot.shoutwiki.com/wiki/ASUS_RT-BE96U
December 9, 2023 at 7:25 am #28389New ASUS GT-BE98 Firmware version 3.0.0.6.102_33001
Version 3.0.0.6.102_33001
2023/12/04
Bug Fixes and Enhancement
– Optimizes WiFi 7 device connection issues
– Addresses abnormal behavior in Dual WAN load balance mode for enhanced stability.
– Optimizes IPSec VPN and Instant Guard connection performance for improved speed and reliability.
– Resolves issues preventing certain IPTV profiles from functioning correctly.https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
February 2, 2024 at 6:24 pm #30366Latest ASUS GT-BE98 Firmware version 3.0.0.6.102_33570
Version 3.0.0.6.102_33570
2024/01/31
Bug Fixes and Enhancements:
– Resolved the issue of the client being unable to bind on the AiMesh node.
– Fixed the problem where an AiMesh node could not broadcast WiFi signal normally – when creating a Guest Network Pro WiFi-only
– Corrected the UI display error related to Link Aggregation.
– Addressed the error in the Guest Portal function.
– Enhanced the stability of the AiMesh system.
– Resolved issues where Guest Network Pro and VPN connections were unable to access the internet due to DNS errors occurring when certain functions were activated.
– Removed execute mode from the backup file.
– Addressed translation issues in Guest Network Pro – Guest Portal – Terms of Service.
– Corrected the VPN WireGuard client profile name issue.
– Modified VPN routing rules.
– Fixed the access LAN issue after deleting the IoT Network.
– Addressed the VPN default connection issue.https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
April 24, 2024 at 4:25 pm #31981New ASUS GT-BE98 Firmware version 3.0.0.6.102_34372
Version 3.0.0.6.102_343722024/04/23New Features:
Introduced AURA Night Mode.
Added Multi-link Operation (MLO) network in Guest Network Pro.
Added automatic WAN/LAN detection feature.Bug Fixes and Performance Enhancements:
Enhanced connectivity for WiFi 7 devices.
Fixed client binding issues on AiMesh nodes.
Resolved AiMesh node broadcast issues in Guest Network Pro.
Corrected Link Aggregation UI errors.
Fixed Guest Portal bugs.
Improved AiMesh system stability.
Addressed DNS errors affecting internet access for Guest Network Pro and VPN connections.
Resolved the issues of WireGuard client profile names.
Fixed dual WAN and VLAN 4094 IoT issues.Security Updates:
Fixed code execution in custom OVPN.
Fixed CVE-2023-48795, CVE-2023-41913In a completely sane world, madness is the only freedom (J.G.Ballard).
April 18, 2025 at 8:02 pm #37214ASUS GT-BE98 Firmware version 3.0.0.62.102_36911
2025/04/17
4. Enhance system access control mechanisms.https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
April 24, 2025 at 6:13 pm #37306ASUS GT-BE98 Firmware version 3.0.0.62.102_37838
2025/04/23
• Support 10G Hikari Cross (v6plus and OCN Virtual Connect)
• Implemented a security patch to address an OpenVPN issue.
• Fixed display issues that could occur during the login process.
• Fixed a potential DNS Open Resolver vulnerability.
• Fixed a problem affecting 5 GHz connections when operating in repeater mode.
• Fixed an anomaly in the wireless scheduler functionality.
• Fixed an issue preventing the configuration of time scheduling for the SDN client.
• Fixed an issue causing Movistar IPTV to malfunction due to incorrect firewall rules.
• Improve 5G WiFi connection stability
• Improved compatibility with loT devices when using WPA2+WPA3 security protocols.
• Improved the stability of remote connections via the app.
• Enhanced the stability of MLO (Multi-Link Operation) connections.https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
May 8, 2025 at 7:12 am #37417Small change, ASUS GT-BE98 Firmware version 3.0.0.6.102_37839
2025/05/07
- Support 10G DS-Lite (Xpass and transix)
May 9, 2025 at 11:55 am #37440PPPoE with Native IPv6 it’s ok
IPoE (Ip automatic) with Native IPv6 I don’t get IPv6 address.Bye.
May 9, 2025 at 12:03 pm #37445Did ‘IPoE (Ip automatic) with Native IPv6’ work before update ?
May 9, 2025 at 9:30 pm #37476I never mentioned it.
But it didn’t work with the previous version either.You need to login in order to vote
May 10, 2025 at 6:09 am #37477September 14, 2025 at 10:50 am #39635Version 3.0.0.6.102_37902 has a UPnP or/and firewall bug.
To resolve this, install the latest release of Gnuton.You need to login in order to vote
September 15, 2025 at 6:59 am #39640September 15, 2025 at 7:12 am #39643. Roberto Said:Interesting, for miniupnpd 2.2* this isn’t a fault with UPnP itself, but rather with how miniupnpd’s listener logic prioritizes IPv6 over IPv4. Disabling IPv6 (
option ipv6_disable '1'
) or removingipv6_listening_ip
restores IPv4 functionality, which confirms the issue is IPv6-specific.Are you using IPv6 and/or (dual stack) and what version miniupnpd’s is your ASUS ROG Rapture GT-BE98 using ?
