ROG Rapture GT-BE98 – Official Thread ASUS GT-BE98 Firmware version 3.0.0.6.102_32745 Version 3.0.0.6.102_32745 2023/11/21 This is the Initial firmware release for the ROG Rapture GT-BE98 https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ROG Rapture GT-BE98 – Official Thread ASUS GT-BE98 Firmware version 3.0.0.6.102_32745 Version 3.0.0.6.102_32745 2023/11/21 This is the Initial firmware release for the ROG Rapture GT-BE98 https://rog.asus.com/networking/rog-rapture-gt-be98-model/helpdesk_bios/
Viewing 15 posts - 16 through 30 (of 38 total)
  • #39646
    • Replies 8,739
    FWiW, my ASUS DSL-AX82U running @GNUton firmware is running miniupnpd 2.3.8
    #39647
    AvatarRoberto
    • Replies 42
    . UK Sentinel Said:
    Interesting, for miniupnpd 2.2* this isn’t a fault with UPnP itself, but rather with how miniupnpd’s listener logic prioritizes IPv6 over IPv4. Disabling IPv6 (option ipv6_disable '1') or removing ipv6_listening_ip restores IPv4 functionality, which confirms the issue is IPv6-specific.
    Are you using IPv6 and/or (dual stack) and what version miniupnpd’s is your ASUS ROG Rapture GT-BE98 using ?
    IPv6 native.
    miniunpnpd 2.2.0.
    #39685
    AvatarRoberto
    • Replies 42
    Asus is not responding to my feedback.
    #39686
    • Replies 8,739
    I will check with ASUS, when you sent your feedback, did you use the same email address as you used with this forum registration ?
    #39687
    AvatarRoberto
    • Replies 42
    Yes
    #39688
    • Replies 8,739
    AvatarRoberto
    • Replies 42
    . UK Sentinel Said:
    Have you some news for this bug?
    • Replies 8,739
    I was CC’d in the email chain last week that went to the appropriate ASUS dept, just have had no feedback as yet.
    I will chase them again on Thursday
    #39847
    • Replies 8,739
    As an update, I still have not had any feedback from ASUS regarding ASUS GT-BE98 Firmware version 3.0.0.6.102_37902 and miniunpnpd 2.2.0.
    Doesn’t look promising but thank goodness for third party developers such as @RMerlin and @GNUton.
    #39848
    AvatarRoberto
    • Replies 42
    Thanks.
    I spoke with gnuton, who told me he’s had a busy life.
    It seems he’s now back to “working” on new releases.
    #39849
    • Replies 8,739
    • Replies 8,739
    ASUS GT-BE98 Firmware version 3.0.0.6.102_39244
    2026/02/04
    Improvements:
    – Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
    – Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    – Refined accessibility-related UI and interaction details.
    – Enhanced stability for 2.5G LAN/WAN port operations.
    – Improved overall remote connection stability.
    – Improved system behavior when using System diagnostic on feedback page.
    Bug Fixes:
    – Fixed incorrect connection status display for certain Wi-Fi devices.
    – Fixed AiMesh nodes not displayed correctly in the device list.
    – Fixed a disconnection issue that occurred after enabling the MAC Filter.
    – Fixed main network connectivity issue when enabling IPv6 for both the main network and GUEST NETWORK PRO.
    – Fixed a system issue that caused AiCloud features to appear on unsupported models.
    Security Enhancements:
    – Enhanced system API validation for stronger protection consistency.
    – Strengthened command handling and system resource access controls.
    – Improved system logging and security event recording mechanisms.
    #41818
    AvatarRoberto
    • Replies 42
    And again UPnP don’t work……
    #41819
    • Replies 8,739
    That is annoying, just to check, on your router what does it say under Advanced Settings > System Log > Port Forwarding
    #41847
    AvatarRoberto
    • Replies 42
    Is it all ok, 3074.
    but after a while the nat becomes moderate
    the solution is always the same, install gnuton/merlin.
    common….adaptive QoS doesn’t work again
    xbox remote play does not work with both gnuton and stock firmware.
    To make xbox remote play work (outside my lan) you need to forward port 9002 udp……..with DSL AX82U (stock fw no problem)
    Ping radar……not convincing, I live in Italy and I know how much the ping must be in America or Eastern Europe ;-)
    there is nothing to be done, asus does not listen to my feedback and/or what is written on the official forum.
    p.s. Some issue for all family Wi-Fi7
    • This reply was modified 9 months, 1 week ago by AvatarRoberto.
