› UKTH forums › 💻 Computers › 💬 Antivirus & Firewalls › wlanext.exe hogging CPU Resources
- This topic has 0 replies, 1 voice, and was last updated 4 years, 2 months ago by
- July 7, 2021 at 11:58 am #14246
So for the last week my Laptop FAN has been on all the time, after some investigation I found via Task Manager that the wlanext.exe file was using 30 – 50% CPU resources and is associated with the Windows Wireless LAN 802.11 Extensibility Framework.
So looking online, seems to be either a file corruption or an Trojan Coin Miner (BitCoin Miner) that back in 2019 / 20 used the infected computer system’s sources to mine electronic currency without your consent.
The wlanext.exe was located in C:\Windows\wmu3\wlanext.exe and I found a second instance located C:\Windows\System32 which is where the original /official wlanext.exe should be located .
C:\Windows\System32 is the correct directory for wlanext.exe, C:\Windows\wmu3\wlanext.exe should not be there.
So I killed the wlanext.exe service in Task Manager and then deleted wlanext.exe from the C:\Windows\wmu3\ directory.
Now laptop is running smoothly and fan is working as it should be ?
I assume this is just a one off and do not hope the Trojan Coin Miner is making a comeback as it did in 2019 – 20 and interestingly, both my AVAST AV and MalwareBytes did not find anything unusual .
A good read on wlanext.exe if you are interested:
