› UKTH forums › 🛜 Wireless Routers & Modems › 💬 Zyxel & Wireless › Zyxel XMG3927-B50A – G.fast Zyxel XMG3927-B50A An expensive but tweak-able Modem Router that supports G.fast and has a Broadcom chipset Specs: Zyxel XMG3927-B50A Gateway and Controller 10, 100, 1000 Mbit/s – Access Point (AES,WMM,WPA2-PSK,...
- This topic has 3 replies, 2 voices, and was last updated 4 years, 1 month ago by
- February 13, 2021 at 6:16 am #11909
Zyxel XMG3927-B50A
Specs:
Zyxel XMG3927-B50A Gateway and Controller 10, 100, 1000 Mbit/s – Access Point (AES,WMM,WPA2-PSK, 10, 100, 1000 Mbit/s, IEEE 802.11ac, IEEE 802.11n, 1.7 Gbit/s, Ethernet (RJ-45), 220 mm)
February 13, 2021 at 6:23 am #11910Access to online view only manual (English) for the Zyxel XMG3927-B50A
https://drive.google.com/file/d/1UfU5mbOplHCKC7zLVOpclYJ9CkIGs2ew/view
September 8, 2021 at 7:37 am #15078I own this G.fast Modem. Great router. Can access to DSLStats for G.fast stats:
xdslctl info –stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 1
Max: Upstream rate = 42688 Kbps, Downstream rate = 239093 Kbps
Bearer: 0, Upstream rate = 42600 Kbps, Downstream rate = 238805 KbpsLink Power State: L0
Mode: G.fast Annex A
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 3.1 3.1
Attn(dB): 38.6 0.0
Pwr(dBm): 0.0 4.0Since Link time = 4 days 8 hours 34 min 33 sec
FEC: 1503914 1903349
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
HostInitRetr: 0
FastRetr: 0
FailedRetr: 0
FailedFastRetr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
ZySH>The wifi was excellent getting throughput speed of 228 down and 42 up.
September 8, 2021 at 8:49 am #15079Welcome, yes the Zyxel XMG3927-B50A with its Broadcom chipset does seems to work well and wifi from what I have read in the past is also good for an all-in-one unit.
IPv6 on BT used to be an issue but alas not sure if this was ever resolved.
