ASUS BQ16 Pro- Firmware version 3.0.0.6.102_36869
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS BQ16 Pro- Firmware version 3.0.0.6.102_36869
Viewing 15 posts - 1 through 15 (of 27 total)
  • #35443
    • Replies 8,737
    New Firmware
    ASUS ZenWiFi BQ16 Pro Firmware version 3.0.0.6.102_36869
    Version 3.0.0.6.102_36869
    2025/01/20
    Bug Fixes and Enhancements:
    1. Enhanced Client Connection Stability.
    2. WPA Encryption Settings Update.
    Added new configuration options for WPA encryption, including the option to select AES for improved client compatibility. This settings can be found under “Network > Main Network”.
    3. Improved AiMesh Backhaul Compatibility.
    4. Fixed GUI Bugs.
    5. Strengthened certificate protection, providing enhanced data security.
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-bq16-pro/helpdesk_bios?model2Name=ASUS-ZenWiFi-BQ16-Pro
    #35451
    • Replies 148
    Interesting I wonder if some of these changes will eventually come to the bt10. Specifically the backhaul improvements as I do see backhaul issues on the 10.
    • This reply was modified 1 year, 9 months ago by AvatarSuperhands.
    #35453
    • Replies 8,737
    I’ll drop ASUS a message and ask when the next version might be released.
    #35457
    AvatarMultiDoc
    • Replies 15
    Any idea if the non Pro version of the BQ16 will also get any update for us in the UK?
    #35458
    • Replies 8,737
    Welcome and I will check with ASUS
    #35459
    AvatarMultiDoc
    • Replies 15
    Thanks for the welcome ! And I appreciate your input (main if not sole reason I have been lurking as guest these forums, decided to register now that I have the BQ16 setup).
    #35466
    • Replies 148
    welcome to the forum multidoc
    #35469
    • Replies 8,737
    So ASUS have come kindly come back and said, Firmware release for the ASUS ZenWiFi BQ16 and ASUS ZenWiFi BT10 …..
    • ASUS ZenWiFi BQ16 – BQ16 should be released in a few days
    • ASUS ZenWiFi BT10 – by end of first QTR 2025
    I will post changelog as soon as I receive it.
    #35470
    AvatarMultiDoc
    • Replies 15
    Great, thanks for the update. To be honest, I bought a set of BT8s first but after some further research into these I realised that ongoing and up to date support would potentialy become problematic for the “lesser” versions long term (ie: the BT8 and BT10), so I returned the BT8 set and replcaed it with BQ16s in hoping that it would be better supported with firmware updates etc (although for my needs on paper the BT8 was more than capable and enough).
    #35471
    • Replies 148
    I think there’s minimum support time vendors have to support them now by law – 5 years I think? But I would assume BQ16 will get the updates first and then they will filter their way down to the 10 and 8 some time after.
    #35472
    • Replies 8,737
    ASUS will offer security update support to the networking products complied with UK PSTI(Product Security and Telecommunications Infrastructure Act) until the date specified below.
    The PSTI came into affect on the 29th Apr 2024, 4 years is the requirement but ASUS do usually go beyond that.
    Note: frequency of updates is a totally different scenario
    https://www.asus.com/uk/support/faq/1051929/
    #35473
    AvatarMultiDoc
    • Replies 15
    Support for BQ16 until December 2026 ?!?!?!?! Seriously ? Must be a mistake… It comes with supposedly at least 3 year warranty but updates and security support for not even 2 years ?
    #35474
    • Replies 8,737
    Guarantee a typo form their perspective, ASUS are not dynamic in this area.
    ASUS ZenWiFi BQ16 was released in 2024, so support (firmware) should be to at least 2028.
    #35475
    • Replies 8,737
    Changelog for ASUS ZenWiFi BQ16
    Release Note:
    Added new configuration options for WPA encryption, including the option to select AES for improved client compatibility. This setting can be found under “Network > Main Network”.
    4. Strengthened certificate protection, providing enhanced data security.
    #35481
    AvatarMultiDoc
    • Replies 15
    Release Note:
    This is good news, unfortunately when i try to download it it gives a “404 Not Found” blank page….
    FYI i try to download it from here: https://www.asus.com/uk/supportonly/zenwifi%20bq16%20/helpdesk_bios/
    Any idea ?
