BT10 HTTP downloads causing high CPU usage I have been investigating why HTTP downloads cause high cpu usage on the bt10 where as https doesn’t – noticed in particular on microsoft store downloads which are http and…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › BT10 HTTP downloads causing high CPU usage I have been investigating why HTTP downloads cause high cpu usage on the bt10 where as https doesn’t – noticed in particular on microsoft store downloads which are http and...
Viewing 14 posts - 1 through 14 (of 14 total)
  • #44651
    • Replies 150
    I have been investigating why HTTP downloads cause high cpu usage on the bt10 where as https doesn’t – noticed in particular on microsoft store downloads which are http and cause max cpu usage on one core as the traffic isn’t being accelerated.
    Long story short I found this firewall rule
    iptables -t mangle -D PREROUTING -i br0 -p tcp -m tcp –dport 80 -j SKIPLOG
    This stops HTTP traffic from being learned by the flow cache so it’s all processed by CPU.
    If I delete this, it all works as expected. HTTP downloads go full speed and back down to negligible CPU usage.  The issue is this gets put back in with every reboot or firewall restart.
    I have submitted some feedback via the form on the asus portal.  @UK Sentinel – would it be possible please to feed this back via your Asus contacts to see if this is something they can do something about?
    I believe this rule may be intended to keep admin portal traffic off the flow cache but is actually just catching all HTTP traffic and causing it to be processed by CPU and not hw accelerated.
    #44652
    • Replies 8,745
    Interesting, when I contact ASUS and to enable ASUS to locate your feedback, did you use the same email address that you registered with on this forum?
    If not, can you email me the address you used in the following link;
    Contact
    #44653
    • Replies 150
    Yeah should be the same email.
    I think from other research I’ve done the same firewall rule exists on other models too. You may be able to replicate it by downloading from a http source and see one of your cpu cores get pinned near 100% in the web console. In my case downloading a big game via the Microsoft store was easy to try as they seem to not use https.
    switching to a https source such as steam the cpu barely gets off baseline
    • This reply was modified 2 weeks, 6 days ago by AvatarSuperhands.
    #44655
    • Replies 8,745
    Maybe an obvious question, apart from Microsoft Store downloads which is famous for opening large numbers of connections, did you try another online HTTP service ?
    If so, which HTTP services did you use ?
    #44656
    • Replies 150
    Yeah used the 5gb port 80 test file on https://www.thinkbroadband.com/download
    Very stark difference in usage to https, and confirmed the traffic not being hw accelerated via ssh.
    Deleting the fw rule speeds it all back up and cpu down to baseline
    #44658
    • Replies 8,745
    Thanks and I will chat with ASUS.
    FWIW, I just tried an HTTP download (http://212.183.159.230/1GB.zip) on my RT-BE92U running ASUSWRT-Merlin, and CPU1 or any other never went above 30%. However, I am using CAKE QoS.
    #44661
    • Replies 150
    Yeah I am just using default fw as Merlin not supported so no cake.
    but the difference was stark, hw accelerated https barely got off background utilisation so only maybe 3 or 4 % cpu
    #44662
    • Replies 8,745
    I forgot to ask, what version of firmware are you currently running and did this happen with previous firmware releases?
    #44663
    • Replies 150
    Using 3.0.0.6.102_39437 , it did happen on prior versions as well
    #44664
    • Replies 8,745
    Thanks, I’ll include that in the email I send to ASUS
    #45213
    • Replies 150
    Did Asus happen to acknowledge the issue at all?
    #45214
    • Replies 8,745
    Have not had any feedback from ASUS on this, I will chase them again next week.
    #45215
    • Replies 150
    Thanks!
    separately, I understand a chunk of extra 6ghz bandwidth has been freed up and approved for home WiFi use in the past few weeks. Wonder if Asus will be incorporating that into a fw update or if they’ll only do it for new routers
    #45216
    • Replies 8,745
    The new approval is a UK-only decision by Ofcom (effective 10 November) expanding licence-exempt 6 GHz home Wi-Fi from 6425 MHz up to 6585 MHz, freeing up an extra 160 MHz channel without needing cloud coordination (AFC).
    However, we’re unlikely to see ASUS push a firmware update for this anytime soon. Because the EU has put on hold this band until at least 2028, the UK is sitting on its own and since ASUS (and Broadcom’s drivers) typically lump the UK in with standard EU regional profiles, they probably won’t rush to maintain a UK-only channel table until Europe aligns.
    But hopefully I’m wrong
