ASUS DSL-AC88U Project
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-AC88U Project
  • #11066
    Moved Topic from DSL-AX82U
    #11061
    Avatarn13ldo
    • Replies 31
    Guys/Girls,
    Is there any component of the current 591 build firmware (debug or otherwise) that’s available as source from ASUS? Given its a Linux implementation surely there should be parts of it available under GNU licensing? Should I be taking this query to ASUS directly?
    Have begun sniffing around build 591 with binwalk..
    Avatarn13ldo
    • Replies 31
    Decided to compare firmware production 591 versus debug 591 (telnet enabled)
    #11071
    Yes, they should be under the GNU licensing , I can PM you an email address and name if u wish for ASUS ?
    #11083
    Avatarn13ldo
    • Replies 31
    [quote quote=11071]Yes, they should be under the GNU licensing , I can PM you an email address and name if u wish for ASUS ?[/quote]
    Yes thanks, that would be appreciated.
    #11088
    [quote quote=11083]
    Yes thanks, that would be appreciated.[/quote]
    I have sent you an email
    #11090
    Avatarn13ldo
    • Replies 31
    [quote quote=11088]
    I have sent you an email [/quote]
    Thanks, received. Email sent to the target
    Fingers and thumbs crossed
    #11118
    Avatarn13ldo
    • Replies 31
    No response from ASUS as yet, early days.
    Received the £60 DSL-AC88U, supposedly wouldn’t turn on. Works fine for me…. user error me thinks.
    #11119
    [quote quote=11118]No response from ASUS as yet, early days. Received the £60 DSL-AC88U, supposedly wouldn’t turn on. Works fine for me…. user error me thinks.[/quote]
    Alas I did note in your original email that you had not mentioned that you had spoken to UK Sentinel, I will speak with ASUS and see what happens
    #11121
    Avatarn13ldo
    • Replies 31
    [quote quote=11119]
    Alas I did note in your original email that you had not mentioned that you had spoken to UK Sentinel, I will speak with ASUS and see what happens [/quote]
    What I didn’t screen capture was that I forwarded your email to ASUS with my message at the top. Pretty sure they would have spotted your email in mine. An extra reminder directly from yourself can’t harm anything surely.
