Asus ET8 UK release Hello all I live in the UK and I was about to order the Asus XT8 Mesh system but then I read about the newer model ET8 that was released…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › Asus ET8 UK release Hello all I live in the UK and I was about to order the Asus XT8 Mesh system but then I read about the newer model ET8 that was released...
Viewing 11 posts - 31 through 41 (of 41 total)
  • #16485
    Skalamanga
    • Replies 4
    Asus ET8 UK release
    See last paragraph.
    Forum keep failing when I try to quote the message, saying a potentially unsafe operation has been detected
    #16495
    • Replies 8,749
    Could not find the reference, best to Assume ET12 will be released EU/UK  in the new year (spring) and I will check with ASUS just to make sure ;)
    #16539
    • Replies 8,749
    Ok, so I have had feedback from ASUS and as originally discussed, the ET12 will be released EU/UK  in the new year at some point
    #26426
    • Replies 8,749
    New ASUS ZenWiFi ET8 Firmware version 3.0.0.4.388_23759
    Version 3.0.0.4.388_23759
    2023/08/03
    New features:
    1.Plug, Share & Surf: Turn Your ET8 into a 4G/5G Hotspot. Unleash the power of 4G and 5G connectivity without the need for a new router. With your ASUS router and smartphone, you can access high-speed internet instantly. It’s as simple as plugging in your phone and sharing its network. Please refer to https://asus.click/AutobackupWAN
    2.DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    3.Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    4.Supported WireGuard VPN server and client.
    5.Supported VPN fusion. It can easily achieve VPN connection to network devices like Smart TV, Game consoles and without installing the VPN client software.
    6.Supported new devices connection notification.
    7.Supported connection diagnostic on the ASUS router app.
    8.Supported Instant Guard 2.0 which helps easily invite family or friends to join the VPN connection.
    9.Upgraded parental control and added reward, new scheduler for flexible setting
    Security updates:
    1.Enabled and supported ECDSA certificates for Let’s Encrypt.
    2.Allowed binding DDNS to a user’s account to reduce the risk of MITM attacks
    3.Enhanced protection for credentials.
    4.Enhanced protection for OTA firmware updates.
    5.Fixed CVE-2023-34359,CVE-2023-34358 Unauthenticated Denial of Service
    6.Fixed CVE-2023-34360 Stored XSS
    7.Fixed DoS vulnerabilities in firewall configuration pages.
    8.Fixed DoS vulerabilities in httpd.
    9.Fixed information disclosure vulnerability.
    10.Fixed CVE-2023-28702 and CVE-2023-28703.
    11.Fixed null pointer dereference vulnerabilities.
    12.Fixed the cfg server vulnerability.
    13.Fixed the vulnerability in the logmessage function CVE-2023-35086/ CVE-2023-35087.
    14.Fixed lighttpd vulnerability, CVE-2023-35720.
    15.Fixed several curl vulnerabilities including CVE-2023-28322, CVE-2023-28321, and CVE-2023-28319.
    16.Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
    17.Fixed openssl vulnerability, CVE-2023-0464.
    18.Fixed ReadyMedia vulnerabilitym CVE-2020-28926.
    19.Fixed UPnP vulnerability CVE-2020-12695.
    20.Patched a command injection vulnerability to improve overall security.
    21.Strengthened protection against SSH brute force attacks.
    22.Fixed the cfg server vulnerability.
    23.Fixed the vulnerability in the logmessage function.
    24..Fixed CVE-2022-46871
    25.Fixed Client DOM Stored XSS.
    https://www.asus.com/us/supportonly/zenwifi%20et8/helpdesk_bios/
    #34233
    • Replies 8,749
    New ASUS ZenWiFi ET8 Version 3.0.0.4_388_25112 – V1
    2024/09/23
    1. Optimized memory management mechanisms, improving system efficiency and stability.
    5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-et8/helpdesk_bios?model2Name=ASUS-ZenWiFi-ET8
    #34236
    • Replies 8,749
    and new firmware for the ZenWiFi ET8 v2 has been released.
    ASUS ZenWiFi ET8 V2 Firmware version 3.0.0.4.388_24832
    Version 3.0.0.4.388_24832
    2024/09/26
    #36124
    • Replies 8,749
    Latest ASUS ZenWiFi ET8 Firmware version 3.0.0.4.388_25138
    2025/03/20
    This version of firmware is only applicable to ZenWiFi ET8 of HW Ver: 1.0
    4. Enhance system access control mechanisms.
    #37515
    • Replies 8,749
    ASUS ZenWiFi ET8 (V1) Firmware version 3.0.0.4.388_25139
    2025/05/08
    This version of firmware is only applicable to ZenWiFi ET8 of HW Ver: 1.0, please check the product label before utilizing. You can check the hardware version from the product SN label or box label.
    • Improved compatibility with certain IoT devices.
    #37778
    • Replies 8,749
    ASUS ZenWiFi ET8 V2 Firmware version 3.0.0.4.388_24863
    2025/05/12
    This version of firmware is only applicable to ZenWiFi ET8 of HW Ver: 2.0, please check the product label before utilizing. You can check the hardware version from the product SN label or box label.
    #39465
    • Replies 8,749
    ASUS ZenWiFi ET8 Firmware version 3.0.0.4.388_25174
    2025/09/09
    Security Enhancements:
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
    #39967
    • Replies 8,749
    ASUS ZenWiFi ET8 Firmware version 3.0.0.4.388_25186
    2025/10/28
    – Enhanced system stability.
    – Addressed multiple security weaknesses in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
    – Fixed a privilege escalation vector in the IFTTT token exchange mechanism
    – Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.
