› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS GT-AXE16000 – Official Thread
- This topic has 9 replies, 2 voices, and was last updated 3 weeks, 2 days ago by
April 19, 2023 at 7:55 pm #23842
Latest ASUS GT-AXE16000 Firmware 3.0.0.4.388.23012
Firmware version 3.0.0.4.388_23012
New features:
– Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections.
Please refer to https://asus.click/SurfsharkVPN– iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source.
Please refer to https://asus.click/AutobackupWAN– DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one.
Please refer to https://asus.click/ASUSDDNSBug fixes and functionality modifications:
– Resolved the issue with login and password changes.
– Resolved the IPSec VPN connection issues.
– Resolved the Instant Guard connection issues.
– Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
– Fixed the issue where Traffic Analyzer sometimes couldn’t record data.
– Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
– Fine-tuned the description for port status.
– Enabled DynDNS and No-IP DDNS to use IPv6.
– Fixed AiMesh preferred AP identification in site survey results.
– Updated timezone list for Greenland, Mexico, and Iran.
– Modified the USB application option text in dual WAN.
– Allowed WireGuard Server clients to access the Samba server.
– Fixed memory leak issue.
– Enabled the failback function when using the iOS/Android USB backup WAN.Security updates:
– Enabled and supported ECDSA certificates for Let’s Encrypt.
– Enhanced protection for credentials.
– Enhanced protection for OTA firmware updates.
– Fixed DoS vulnerabilities in firewall configuration pages.
Thanks to Jinghe Gao’s contribution.
– Fixed DoS vulerabilities in httpd.
Thanks to Howard McGreehan.
– Fixed information disclosure vulnerability.
Thanks to Junxu (Hillstone Network Security Research Institute) contribution.
– Fixed CVE-2023-28702 and CVE-2023-28703.
Thanks to Xingyu Xu(@tmotfl) contribution.
– Fixed null pointer dereference vulnerabilities.
Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.You need to login in order to vote
December 19, 2023 at 7:34 am #28515New ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.04.388_24329
Version 3.0.04.388_24329
2023/12/18
New Features:
– Added new IPTV profiles, including Celcom, Celcom-TM, and UNIFI-Business+VoIP.Bug Fixes and Enhancements:
– Fixed WAN connection issues.
– Resolved OpenVPN server TAP mode issue.
– Added MTU setting for WireGuard client.
– Ensured consistent display of client status on the WireGuard server.
– Enhanced system stability when accessing the WireGuard server with DMZ enabled.
– Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
– Fixed connection in load-balance mode when both WANs have static IPs.
– Resolved USB path display issue in RE Mode.
– Improved VPN client internet accessibility with AiProtection.Security Fixes:
– Upgraded to the latest dropbear version.
– Fixed a stack overflow vulnerability.https://rog.asus.com/uk/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
September 28, 2024 at 8:08 pm #34225ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.0.4.388_24374
Version 3.0.0.4.388_24374
55.4 MB
2024/09/271. Optimized memory management mechanisms, improving system efficiency and stability.
5. Perfected JavaScript-related security mechanisms, offering a more secure web interaction environment.Please unzip the firmware file, and then verify the checksum.
SHA256: 8722f036d092ee2dd98c9eef4f961a3bdd20e4248d9bace6d2161bea0bf004dehttps://rog.asus.com/uk/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
November 14, 2024 at 5:47 am #34857ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.0.4.388_24403
Version 3.0.0.4.388_24403
55.51 MB
2024/11/131. Strengthened input validation and data processing workflows to further protect information security.
6. Strengthened certificate protection, providing enhanced data security.Please unzip the firmware file, and then verify the checksum.
SHA256: bc323982c9ed7d967f365fe1fcd26ffc1c5208c927e3b5ec589ebcc1387c8003https://rog.asus.com/ca-en/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
March 12, 2025 at 3:10 pm #35959ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.0.6.102_36382
2025/03/12
1.Fixed the UI issue in Chrome.
2.Fixed client binding issues in Mesh scenarios.
3.Enhanced input parameter handling techniques to improve data processing stability and system security.
4.Enhance system access control mechanisms.
5.To enhance software functionality, we have implemented architectural changes. As a result, some settings will require manual reconfiguration:
-Wi-Fi schedule settings will not be migrated and must be manually reconfigured.
-Only the first guest network of each Wi-Fi band will be migrated; additional guest networks need to be reconfigured manually.https://rog.asus.com/ca-en/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
April 11, 2025 at 5:19 pm #37097ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.0.6.102_36383
2025/04/10
- Improved system stability and security by fixing a kernel integrity validation issue.
May 22, 2025 at 7:47 pm #37840ASUS ROG Rapture GT-AXE16000 Firmware version 3.0.0.6.102_36387
2025/05/21
- Improved compatibility with certain IoT devices.
March 19, 2026 at 7:35 am #42193ASUS GT-AXE16000 Firmware version 3.0.0.6.102_36488
2026/03/16
Security:
Strengthened input sanitization mechanismhttps://rog.asus.com/uk/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
May 11, 2026 at 6:16 pm #42681ASUS GT-AXE16000 Firmware version 3.0.0.6.102_36489
2026/05/11
Security Fixes:
– Enhanced DNS name handling to address a potential memory issue that could occur in rare cases during name format conversion, improving system security and robustness.
– Improved safeguards for execution modules to reduce the risk of substitution during certain processes.https://rog.asus.com/uk/networking/rog-rapture-gt-axe16000-model/helpdesk_bios/
October 6, 2026 at 5:05 pm #43993ASUS GT-AXE16000 Firmware Version 3.0.0.6.102_37547
2026/10/06
Security Fixes:
AiCloud: Strengthened the data handling mechanism for the network neighborhood host list.
AiCloud: Improved how share link identifiers are generated, and adjusted the file and disk information query process.
AiCloud: Strengthened authentication and path validation for remote file access.
System protection service: Adjusted address parameter validation and event logging, strengthening access control between local services.Certificate import process: Adjusted file handling and password passing, with stricter parameter validation.
AiMesh: Adjusted data access protection during the node joining process, improving system stability while connections are being established.System temporary directory: Adjusted the default permissions applied at creation time to narrow local file access.
VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.We recommend updating to this version to maintain optimal protection.
