ASUS RT-AX92U (AX6100) – Official Thread ASUS RT-AX92U Hardware Specs: (basics) CPU1  Broadcom BCM4352 CPU1 Speed  1.8 GHz   ( 2 cores ) Flash1 Size  256 MiB RAM1 Size  512 MiB RAM1 Type  DDR3 ETH chip 1…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX92U (AX6100) – Official Thread ASUS RT-AX92U Hardware Specs: (basics) CPU1  Broadcom BCM4352 CPU1 Speed  1.8 GHz   ( 2 cores ) Flash1 Size  256 MiB RAM1 Size  512 MiB RAM1 Type  DDR3 ETH chip 1...
  • #20799
    Flash1 Size  256 MiB
    RAM1 Size  512 MiB
    RAM1 Type  DDR3
    ETH chip 1  Broadcom BCM4906
    Radio 1 chip  BCM4352
    Radio 2 chip  BCM4352
    Radio 3 chip  BCM43684
    #20800
    ASUS RT-AX92U  Latest Firmware
    Version 3.0.0.4.386.46061
    2022/01/21
    ASUS RT-AX92U Firmware version 3.0.0.4.386.46061
    Security
    – Fixed string format stacks vulnerability
    – Fixed cross-site-scripting vulnerability
    – Fixed informational vulnerability.
    Thanks to Howard McGreehan.
    -Fixed SQL injection vulnerability
    -Fixed json file traversal vulnerability
    -Fixed plc/port file traversal vulnerability
    -Fixed stack overflow vulnerability
    Thanks to HP of Cyber Kunlun Lab
    -Fixed authenticated stored XSS vulnerability
    Thanks to Luke Walker – SmartDCC
    -Fixed LPD denial of service vulnerability
    -Fixed cfgserver heap overflow vulnerability
    -Fixed cfgserver denial of service vulnerability
    Thanks to TianHe from BeFun Cyber Security Lab.
    Added more ISP profile
    Digi 1 – TM
    Digi 2 – TIME
    Digi 3 – Digi
    Digi 4 – CTS
    Digi 5 – ALLO
    Digi 6 – SACOFA
    Maxis – CTS
    Maxis – SACOFA
    Maxis – TNB/ALLO
    and
    Fixed AiMesh guest network issues.
    Fixed DDNS issues where the WAN IP is IPv6
    Fixed UI bugs in Administration –> feedback.
    Fixed time zone error.
    Improved the connection stability.
    https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX92U/FW_RT_AX92U_v300438646061.zip
    #22819
    New ASUS RT-AX92U Firmware version 3.0.0.4.388.22525
    Version 3.0.0.4.388.22525
    Release Date: 2023/02/16
    1. Supported WireGuard VPN server and client.
    7. Fixed USB icon issue in port status.
    8. Fixed HTTP response splitting vulnerability. Thanks to Efstratios Chatzoglou, University of the Aegean.
    9. Fixed status page HTML vulnerability. Thanks to David Ward.
    10. Fixed CVE-2018-1160. Thanks to Steven Sroba.
    11. Fixed cfg_server security issue.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax92u/helpdesk_bios/?model2Name=RT-AX92U
    #34859
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS RT-AX92U Firmware version 3.0.0.4.388_23695
    Version 3.0.0.4.388_23695
    66.8 MB
    2024/11/12
    SHA256: 1730ecd8f23ebff809abb3124de265cf5f946f39b27ae85373740f49b90e8718
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax92u/helpdesk_bios?model2Name=RT-AX92U
    #35856
    ASUS RT-AX92U Firmware version ASUS R3.0.0.4.388_23708
    2025/03/04
    1. Fixed UI compatibility issues with the latest Chrome.
    3. Fixed an issue where WAN and LAN status were displayed incorrectly.
    #37890
    ASUS RT-AX92U Firmware version 3.0.0.4.388_23713 (2025/05/28)
    2025/05/28
    • Improved compatibility with certain IoT devices.
    #39407
    ASUS RT-AX92U Firmware version 3.0.0.4.388_23749
    Version 3.0.0.4.388_23749
    2025/09/03
    Security Enhancements:
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
    #42297
    ASUS RT-AX92U Firmware version 3.0.0.4.388_23807
    2026/03/30
    Improvements-
    – Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
    – Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    – Refined accessibility-related UI and interaction details.
    – Improved overall remote connection stability.
    Security Enhancements-
    – Strengthened input sanitization mechanism
    – Enhanced system API validation for stronger protection consistency.
    – Strengthened command handling and system resource access controls.
    – Improved system logging and security event recording mechanisms.
    #43191
    ASUS RT-AX92U Firmware version 3.0.0.4.388_23842
    2026/08/13
    New Features
    – New Time Zone Options: Added “Vancouver, Whitehorse (PST7)” and “Edmonton, Yellowknife (MST6)” time zone options for Canada.
    Bug Fixes and Enhancements
    – Improved stability during the AiMesh node setup process.
    – Strengthened firewall rule configuration for UPnP, improving port-forwarding stability and firewall rule restoration reliability.
    Security Fixes
    – Strengthened verification when a software component downloads external resources, improving connection security.
    – Strengthened data handling in the system logging function.
    We recommend upgrading to this version to maintain optimal protection.
    #43957
    ASUS RT-AX92U Firmware version 3.0.0.4.388_23895
    2026/10/05
    Security Fixes:
    VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
