ASUS ROG Rapture GT-AX11000 – Official Thread Latest ASUS GT-AX11000 Firmware version 3.0.0.4.388.23285 Release: version 3.0.0.4.388.23285 Date: 2023/05/31 New features: -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ROG Rapture GT-AX11000 – Official Thread Latest ASUS GT-AX11000 Firmware version 3.0.0.4.388.23285 Release: version 3.0.0.4.388.23285 Date: 2023/05/31 New features: -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by...
  • #24926
    • Replies 8,732
    Date: 2023/05/31
    New features:
    -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    -iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
    -DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    -Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
    -Modified the USB application option text in dual WAN.
    -Allowed WireGuard Server clients to access the Samba server.
    -Fixed memory leak issue.
    -Enabled the failback function when using the iOS/Android USB backup WAN.
    -Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
    Security updates:
    -Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
    -Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.
    https://rog.asus.com/networking/rog-rapture-gt-ax11000-model/helpdesk_bios/
    #28381
    • Replies 8,732
    New ASUS GT-AX11000 Firmware version 3.0.0.4.388_24328
    Version 3.0.0.4.388_24328
    2023/12/07
    Bug Fixes and Enhancements:
    – Fixed WAN connection issues.
    – Fixed v6plus related issues.
    – Resolved OpenVPN server TAP mode issue.
    – Added MTU setting for WireGuard client.
    – Ensured consistent display of client status on the WireGuard server.
    – Enhanced system stability when accessing the WireGuard server with DMZ enabled.
    – Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    – Fixed connection in load-balance mode when both WANs have static IPs.
    Security Fixes:
    – Upgraded to the latest dropbear version.
    – Fixed a stack overflow vulnerability.
    https://rog.asus.com/uk/networking/rog-rapture-gt-ax11000-model/helpdesk_bios/
    #34854
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS GT-AX11000 Firmware version 3.0.0.4.388_24394
    Version 3.0.0.4.388_24394
    70.72 MB
    2024/11/13
    SHA256: 377915f7d7eb85c324e3e316cebdb799d4c9a6ba304ce905a8a000cc525aa5d0
    https://rog.asus.com/nl/networking/rog-rapture-gt-ax11000-model/helpdesk_bios/
    #35860
    • Replies 8,732
    ASUS GT-AX11000 Firmware version 3.0.0.4.388_24403
    2025/03/05
    4. Enhance system access control mechanisms.
    #43328
    • Replies 8,732
    ASUS GT-AX11000 Firmware version 3.0.0.4.388_24548
    2026/09/02
    New Features:
    New Time Zone Options: Added “Vancouver, Whitehorse (PST7)” and “Edmonton, Yellowknife (MST6)” time zone options for Canada.
    Strengthened firewall rule configuration for UPnP, improving port-forwarding stability and firewall rule restoration reliability.
    Security Fixes:
    Strengthened data handling in Networks configuration functions.
    Improved data validation in Networks rule list processing.
    Fixed a data-handling issue in the DNS query caching component.
    Strengthened verification when a software component downloads external resources, improving connection security.
    Adjusted the information response mechanism of the device discovery service, strengthening protection of device information.
    Fixed a data-handling issue in a firmware component on a specific model.
    Improved data-display handling in a web function to enhance browsing security.
    Strengthened input data validation in a device-pairing web function.
    Improved data validation in the configuration file upload/sync function.
    Improved how the account service restart process is handled.
    Removed a non-essential internal function endpoint, strengthening overall access control.
    Adjusted the debug file access mechanism, strengthening protection of internal data.
    Strengthened data handling in the system logging function.
    We recommend upgrading to this version to maintain optimal protection.
