ASUS RT-AX59U – Official Thread ASUS RT-AX59U Firmware version 3.0.0.4.388_33144 Version 3.0.0.4.388_33144 2024/01/17   – Resolved IPTV interruptions during extended use. – Addressed Guest Network performance issues with active IPTV. – Added Xtra Range 2.0…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX59U – Official Thread ASUS RT-AX59U Firmware version 3.0.0.4.388_33144 Version 3.0.0.4.388_33144 2024/01/17   – Resolved IPTV interruptions during extended use. – Addressed Guest Network performance issues with active IPTV. – Added Xtra Range 2.0...
Viewing 4 posts - 16 through 19 (of 19 total)
  • #42172
    • Replies 8,737
    ASUS RT-AX59U Firmware version 3.0.0.4.388_34011
    2026/03/16
    Improvements:
    Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
    Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    Refined accessibility-related UI and interaction details.
    Improved overall remote connection stability.
    Security Enhancements:
    Strengthened input sanitization mechanism
    Enhanced system API validation for stronger protection consistency.
    Strengthened command handling and system resource access controls.
    Improved system logging and security event recording mechanisms
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax59u/helpdesk_bios?model2Name=RT-AX59U
    #42668
    • Replies 8,737
    ASUS RT-AX59U Firmware version 3.0.0.4.388_34013
    2026/05/06
    Security Fixes:
    – Enhanced system security by addressing an unsafe remote script execution mechanism in.
    – Improved system security by addressing a heap buffer overflow vulnerability during cache handling.
    We recommend upgrading to this version to ensure up-to-date protection.
    #43171
    • Replies 8,737
    ASUS RT-AX59U Firmware version 3.0.0.4.388_34098
    2026/08/12
    New Features
    – New Time Zone Options: Added “Vancouver, Whitehorse (PST7)” and “Edmonton, Yellowknife (MST6)” time zone options for Canada.
    Bug Fixes and Enhancements
    – Improved stability during the AiMesh node setup process.
    Security Fixes
    – Strengthened verification when a software component downloads external resources, improving connection security.
    – Strengthened data handling in the system logging function.
    We recommend upgrading to this version to maintain optimal protection.
    #44350
    • Replies 8,737
    ASUS RT-AX59U Firmware version 3.0.0.4.388_34156
    2026/10/12
    Security Fixes:
    VPN and account authentication services: Adjusted the handling of connection settings and account data, with stricter parameter validation.
