› UKTH forums › 🛜 Wireless Routers & Modems › 💬 ASUS & Wireless › ASUS RT-AC86U ASUSWRT-Merlin Firmware Updated
- This topic has 4 replies, 1 voice, and was last updated 2 years, 3 months ago by
February 4, 2019 at 3:19 pm #2130
RMerlin on the 2nd February 2019 – released his next stable firmware for the ASUS RT-AC86U (RT-AC86U-384.9) and other models.
Asuswrt-Merlin 384/NG Changelog
384.9 (2-Feb-2019)
– NEW: Temporarily reorganized code in separate branches, to handle Asus’s currently scattered firmware source code releases.The GPL situation for this release is as follow:
o RT-AX88U: Merged GPL 384_5329
o Other models: Merged GPL 384_45149.
o Special binary blobs provided by Asus for the RT-AC87U and RT-AC3200 (compatible with 384_45149).– NEW: Added NFS client support (V2 and V3) to the RT-AC86U and RT-AX88U (already present in older models)
– NEW: Report the number of spatial streams and the PHY type used by wireless clients for models supporting it
– NEW: Display tracked connections on the QoS Stats page (now relabeled “Classification”).
Fields can be sorted by clicking on the column headers.Thanks to FreshJr for his help in deciphering the packet mark values.
– NEW: Implemented ipsec.postconf and strongswan.postconf scripts.
– KNOWN ISSUE: dcd process crashing on RT-AC86U (bug in Trend Micro’s code, outside of my control).
– KNOWN ISSUE: IPv6s on Tracked Connections have their last two bytes set to 00 (bug in Trend Micro’s code truncating the last two bytes).
– KNOWN ISSUE: No IPS events logged (bug in Asus’s code, IPS should work, just fails to log hits)
– KNOWN ISSUE: Networkmap listing may be unreliable.(Bug in Asus’s code)
– KNOWN ISSUE: Users failing to read changelogs will probably complain about the above issues.(Outside of my control).
– CHANGED: Updated wget to 1.20.
– CHANGED: Updated nano to 3.2.
– CHANGED: Updated curl to 7.62.0.
– CHANGED: Updated Chart.js to 2.7.3.
– CHANGED: Updated dnsmasq to 2.80-32-g28cfe36 (themiron)
– CHANGED: Optimized some JS files to reduce their size
– CHANGED: OpenVPN clients can now accept CNs up to 255 chars when using it to validate the certificate.
– CHANGED: No longer reset the OpenVPN client’s description, policy mode and existing rules when uploading an .ovpn config file.
– CHANGED: No longer accept any server-provided route when OpenVPN client set to Policy (Strict).
– CHANGED: Clients bound to DNSFilter rules will no longer bypass it by using DoT. DNSFilter servers that support DoT (like Quad9) will only allow filtered clients to use that server
– FIXED: Firmware update checks would not run at boot time on the RT-AX88U.
– FIXED: Name resolution issues for /etc/hosts entries on HND models (themiron)
– FIXED: Syslog not properly copied to JFFS on reboot (John Bacho)
– FIXED: Volumes not properly unmounted on HND platform (John Bacho)
– FIXED: Added missing TEE Netfilter target on the RT-AC86U
– FIXED: SSH brute force protection didn’t work in Dual WAN load balancing mode.
– FIXED: httpd crashes on RT-AC86U (themiron)
– FIXED: DNSFilter clients could use a different nameserver when using an IPv6 connection
– FIXED: USB disk idle config changes not applying without a reboot.
– FIXED: “Strict” DNS mode wasn’t working properly with OpenVPN clients
– FIXED: Cannot upload JFFS backup on HND modelsIn a completely sane world, madness is the only freedom (J.G.Ballard).
February 4, 2019 at 9:16 pm #2140Well I flashed RMerlins latest stable release (RT-AC86U-384.9) on my RT-AC86U tonight and thus far, seems to have settled in well. did not bother with factory reset this time
https://asuswrt.lostrealm.ca/download
Time will tell ;-)
January 8, 2023 at 9:16 pm #22359So my ASUS RT-AC86U was plugged in yesterday and was running 386.7_2 (24-July-2022) and notified me that a new ASUSWRT-Merlin 386.9 was available.
RT-AC86U_386.9_0_cferom_ubi.w
This release is also available for other AC (not AX) ASUS routers.
Asuswrt-Merlin Changelog:
386.9 (6-Jan-2023)
– NOTE: 386_xx release are only for Wifi 5 (802.11ac) models.
– NEW: Merged with GPL 386_50757.– UPDATED: getdns/stubby to 1.7.2/0.4.2.
– UPDATED: zlib to 1.2.12 + backports.
– UPDATED: openssl to 1.1.1s.
– UPDATED: inadyn to 2.10.0.
– UPDATED: nettle to 3.8.1.
– UPDATED: openvpn to 2.5.8.
– UPDATED: dropbear to 2022.83.
– UPDATED: dnsmasq to 2.88.
– CHANGED: Rebranded DNSFilter as DNS Director. This will prevent
confusion with the company sharing the same name, and
also better describes what the feature does.
– CHANGED: Setting an OpenVPN client to redirect all traffic while
in “Exclusive” DNS mode will now force redirect ALL
DNS traffic just like in VPN Director mode.
While this will allow redirecting clients with
hardcoded DNS servers, it also means that your whole
LAN will lose the ability of doing local name
resolution. It might be best to use VPN Director
in that case to control which client should
be involved in the DNS redirection, or use
DNSFilter instead of Exclusive DNS mode.
editing VPNDirector rules.
– CHANGED: Switched generated self-signed certificate to an
EC certificate.
– CHANGED: Disabled DSS key support in Dropbear SSH.
– FIXED: Wrong temperatures used by the temperature graphs
(386.8 regression)
– FIXED: Guest Network clients couldn’t route through VPN
(regression in 386.4 following a GPL merge).
– FIXED: Clients connected to Guest Network 1 aren’t
redirected to the router’s NTP if NTP interception is
enabled.
– FIXED: Name was truncated to 31 chars when enabling OpenVPN
client’s Server Certificate Name Validation.
– FIXED: CVE-2022-37434 in zlib.
– REMOVED: Interface selector on Speedtest page (no longer
working, possibly due to an ookla client update)In a completely sane world, madness is the only freedom (J.G.Ballard).
January 21, 2023 at 7:11 am #22471So had to revert back to ASUSWRT-Merlin 386.7_2 after experiencing a few wifi and speed issues with the latest RT-AC86U_386.9 release after an initial dirty upgrade.
Did try a factory reset also, but still after a couple of days, internet throughput decreased and some wifi clients had access problems, hopefully just a firmware bug and not my RT-AC86U wifi radios on there way out .
January 23, 2023 at 12:13 pm #22480So two days+ later and my RT-AC86U running ASUSWRT-Merlin 386.7_2 has worked without any issues, seems ASUSWRT-Merlin 386.9 release is not ideal, at least not for myself.
