ASUS RT-AX59U – Official Thread ASUS RT-AX59U Firmware version 3.0.0.4.388_33144 Version 3.0.0.4.388_33144 2024/01/17   – Resolved IPTV interruptions during extended use. – Addressed Guest Network performance issues with active IPTV. – Added Xtra Range 2.0…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX59U – Official Thread ASUS RT-AX59U Firmware version 3.0.0.4.388_33144 Version 3.0.0.4.388_33144 2024/01/17   – Resolved IPTV interruptions during extended use. – Addressed Guest Network performance issues with active IPTV. – Added Xtra Range 2.0...
Viewing 15 posts - 1 through 15 (of 19 total)
  • #29275
    • Replies 8,705
    2024/01/17
    – Added Xtra Range 2.0 support for enhanced connectivity.
    – Rectified potential IPV6-related crashes.
    – Improved roaming efficiency for AiMesh nodes under weak signals.
    – Addressed router crashes during WireGuard setup.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-wifi-routers/rt-ax59u/helpdesk_bios?model2Name=RT-AX59U
    #29304
    • Replies 8,705
    Issues I am receiving reports on are poor connectivity with iOS devices and disable guest wifi Seems to be a workaround
    or maybe skip this release if you are using iOS devices .
    #29357
    • Replies 8,705
    Seems ASUS have pulled their last updated firmware (3.0.0.4.388_33144) from their UK download servers, now the latest firmware version available for the RT-AX59U is Version 3.0.0.4.388_32702
    #30934
    • Replies 8,705
    ASUS have re-released ASUS RT-AX59U Firmware version 3.0.0.4.388_33144
    2024/01/22
    #31395
    • Replies 8,705
    New ASUS RT-AX59U Firmware version 3.0.0.4.388_33305
    Version 3.0.0.4.388_33147
    2024/03/14
    • Resolved IPTV interruptions during extended use.
    • Addressed Guest Network performance issues with active IPTV.
    • Fixed potential Aura RGB crash.
    • Added eXtra Long Range support for enhanced connectivity.
    • Rectified potential IPV6-related crashes.
    • Improved roaming efficiency for AiMesh nodes under weak signals.
    • Addressed router crashes during WireGuard setup.
    • Fixed abnormal activation status in the Gear Accelerator function UI
    Note: ASUS website states Firmware version is 3.0.0.4.388_33305 but Version 3.0.0.4.388_33147 is what is available via download
    #32127
    Avatarcitylightwalrus
    Blocked
    • Replies 55
    ASUS RT-AX59U Firmware version 3.0.0.4.388_33391
    Version 3.0.0.4.388_33391
    37.96 MB
    2024/05/02
    Bug Fixes and Enhancements:
    – Enhanced AiMesh Stability
    – Fixed an issue where the RE product ID was not being updated in the AiMesh topology.
    – Added DS-Lite Support.
    – Corrected a display issue in the OpenVPN server that prevented IPv6 settings from showing correctly.
    – Fixed a persistent GUI issue on ‘Let’s Encrypt Authorization’ that displayed ‘Authorization’ incorrectly.
    – Resolved a bug that prevented offline devices from being deleted in the Router App.
    – Fixed an issue where the system would reboot due to parental control rules with empty enable fields.
    Security updates:
    – Addressed CVE-2023-48795 by updating the dropbear SSH server.
    – Applied patches for CVE-2023-5678 & CVE-2024-0727 from the Ubuntu Repository.
    – Improved security in OpenVPN custom configuration.
    #32136
    • Replies 8,705
    #32680
    Blocked
    • Replies 55
    ASUS RT-AX59U Firmware version 3.0.0.4.388_33392
    Version 3.0.0.4.388_33392
    37.96 MB
    2024/06/28
    – Resolved an issue where the Traffic Analyzer feature was not functioning properly.
    #32681
    • Replies 8,705
    Great news on firmware update ‘bug fix’ for ASUS RT-AX59U
    #34772
    Blocked
    • Replies 55
    ASUS RT-AX59U Firmware version 3.0.0.4.388_33404
    Version 3.0.0.4.388_33404
    37.95 MB
    2024/11/07
    SHA256: e8ad8b4a89a53b936e85d53072bac38cf26e8711caf58b427c1d822d70ec3e0b
    #35146
    • Replies 8,705
    Latest ASUS RT-AX59U Firmware version 3.0.0.4.388_33405
    Version 3.0.0.4.388_33405
    2024/12/04
    #35221
    • Replies 8,705
    New ASUS RT-AX59U Firmware version 3.0.0.4.388_33407
    Version 3.0.0.4.388_33407
    2024/12/27
    1. Improved the stability of AiMesh backhaul connections, resulting in a more robust and reliable mesh network performance.
    #36016
    • Replies 8,705
    Latest ASUS RT-AX59U Firmware version 3.0.0.4.388_33903
    2025/03/13
    1.Fixed the UI issue in Chrome.
    2.Enhanced input parameter handling techniques to improve data processing stability and system security.
    3.Enhance system access control mechanisms.
    #37889
    • Replies 8,705
    ASUS RT-AX59U Firmware version 3.0.0.4.388_33911 (2025/05/27)
    2025/05/27
    • Fixed the IPTV compatibility issue for Now TV.
    #39464
    • Replies 8,705
    ASUS RT-AX59U Firmware version 3.0.0.4.388_33950
    2025/09/09
    Security Enhancements:
    System Improvements:
    – Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list
