ASUS RT-AX86U Series & Pro – Official Thread Official Thread for the new ASUS RT-AX86U / S  Series & Pro: (when it is released) At first look, the new RT-AX86U Pro looks simular to the RT-AX86U, but underneath…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX86U Series & Pro – Official Thread Official Thread for the new ASUS RT-AX86U / S  Series & Pro: (when it is released) At first look, the new RT-AX86U Pro looks simular to the RT-AX86U, but underneath...
Viewing 15 posts - 1 through 15 (of 31 total)
  • #21160
    At first look, the new RT-AX86U Pro looks simular to the RT-AX86U, but underneath the case has a slightly higher clock speed CPU of 2ghz CPU vs 1.8ghz for RT-AX86U.
    First initial firmware:
    Version 3.0.0.4.388.21069
    2022/09/23
    ASUS RT-AX86U Pro Firmware version 3.0.0.4.388.21069
    Initial firmware release
    MD5: 1df477d02c2eb9be7fedff03100a89f8
    https://dlcdnets.asus.com/pub/ASUS/wireless/RT-AX86U_Pro/FW_RT_AX86U_PRO_300438821069.zip
    #22732
    New ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware 3.0.0.4.388.22525
    Release: 3.0.0.4.388.22525
    Date: 2023/02/07
    1.Fixed CVE-2022-46871
    2.Fixed Client DOM Stored XSS.
    3.Improved AiMesh backhaul stability.
    4.Fixed AiMesh topology UI bugs.
    5.Fixed the reboot issue when assigning specific clients in VPN fusion.
    6.Fixed the VPN fusion bug when importing the Surfshark WireGuard conf file.
    7.Fixed network map bugs.
    https://www.asus.com/us/networking-iot-servers/wifi-6/all-series/rt-ax86u/helpdesk_bios/?model2Name=RT-AX86U
    #24385
    Latest ASUS RT-AX86U Pro Firmware version 3.0.0.4.388.23285
    Release: 3.0.0.4.388.23285
    Date: 2023/05/11
    ASUS RT-AX86U Pro will qualify for the ‘Engineered for Intel® Evo™’ designation only when used with firmware version 3.0.0.4.388.23285 or greater. Please download that update to ensure the best experience in compatibility and performance. After Firmware upgrade, please do factory reset to apply the changes.
    New features:
    -Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    -iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
    -DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
    -Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
    -Modified the USB application option text in dual WAN.
    -Allowed WireGuard Server clients to access the Samba server.
    -Fixed memory leak issue.
    -Enabled the failback function when using the iOS/Android USB backup WAN.
    -Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
    Security updates:
    -Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
    -Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u-pro/helpdesk_bios/?model2Name=RT-AX86U-Pro
    #24494
    New ASUS RT-AX86U (RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.388.23285
    Firmware: Version 3.0.0.4.388.23285
    Date: 15-05-2023
    Release Note –
    New features:
    – Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN
    – iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
    – DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS.
    – Resolved the issue with login and password changes.
    – Resolved the IPSec VPN connection issues.
    – Resolved the Instant Guard connection issues
    – Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
    – Fixed the issue where Traffic Analyzer sometimes couldn’t record data.
    – Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
    – Fine-tuned the description for port status.
    – Enabled DynDNS and No-IP DDNS to use IPv6.
    – Fixed AiMesh preferred AP identification in site survey results.
    – Updated timezone list for Greenland, Mexico, and Iran.
    – Modified the USB application option text in dual WAN.
    – Allowed WireGuard Server clients to access the Samba server.
    – Fixed memory leak issue.
    – Enabled the failback function when using the iOS/Android USB backup WAN.
    – The ARP response issue has been resolved, along with the connection issue between the router and the ROG Phone 6 and 7.
    – Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh node
    Security updates:
    – Enabled and supported ECDSA certificates for Let’s Encrypt.
    – Enhanced protection for credentials.
    – Enhanced protection for OTA firmware updates.
    – Fixed DoS vulnerabilities in firewall configuration pages. Thanks to Jinghe Gao’s contribution.
    – Fixed DoS vulerabilities in httpd. Thanks to Howard McGreehan.
    – Fixed information disclosure vulnerability. Thanks to Junxu (Hillstone Network Security Research Institute) contribution.
    – Fixed CVE-2023-28702 and CVE-2023-28703. Thanks to Xingyu Xu(@tmotfl) contribution.
    – Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group-cse hkust contribution.
    – Fixed the cfg server vulnerability. Thanks to Swing and Wang Duo from Chaitin Security Research Lab.
    – Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab COss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.
    https://www.asus.com/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u/helpdesk_bios/?model2Name=RT-AX86-Series-RT-AX86U-RT-AX86S
    #24513
    Hiya,
    Dam a new version… I was just trying to sort out a time to update mine.. guess I might as well wait and see what the feedback is on this new one as I’ve waited so long now…
    Latest ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.388_24231
    Version 3.0.0.4.388_24231
    2023/11/07
    Bug Fixes and Enhancements:
    – Fixed v6plus related Issues.
    – Fixed ipv6 network service filter not work.
    – Resolved OpenVPN Server TAP Mode Issue.
    – Fixed the problem that the AiCloud app cannot add router on Android 9.
    – Ensured consistent display of client status on the WireGuard server.
    – Enhanced system stability when accessing the WireGuard Server with DMZ enabled.
    – Optimized memory utilization and fixed an occasional server error when registering DDNS with an app.
    Security Fixes:
    – Fixed several curl vulnerabilities.
    – Fixed FFmpeg vulnerabilities.
    – Corrected an OpenVPN vulnerability categorized as CWE-134.
    – Strengthened protection against SSH brute force attacks.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u/helpdesk_bios?model2Name=RT-AX86-Series-RT-AX86U-RT-AX86S
    #28000
    Thanks, will see what the verdict is on this before updating…. I only looked last weekend to see if a new version was out lol
    This update references DDNS fix for host name, and memory issue which maybe related to your issue in other post ?
    #28002
    Yes, I saw that and wondered the same :) Also saw some openVPN fixed also but I not noticed any issues myself.
    Anyone tried this yet? I’m holding off atm, not sure if all ok or not atm so will give it a bit more time, thinking might try in new year.
    I have seen views that RAM usage could creep upwards over time but a reboot seems to fix that.
    I seem to recall there was an issue with Guest Wifi 1 (2.4)  having issues in an earlier release, but no idea if that has been fixed etc.
    #28213
    Yes, I saw some reviews of ram usage creeping up and a reboot fixed it but then also others reporting no ram issues so bit 50/50 it seems.  Not seen anything regarding 2.4 WIFI so will hold out a bit and see what opinions are in new year I think. A lot of my stuff runs on 2.4 so don’t want to mess that up.
    New ASUS RT-AX86U Pro Firmware version 3.0.0.4.388_24199 Firmware version 3.0.0.4.388_24199
    Version 3.0.0.4.388_24199
    2024/01/04
    – Resolved guest network connectivity issues on AiMesh nodes by disabling guest network internal access.
    https://www.asus.com/uk/networking-iot-servers/wifi-routers/asus-gaming-routers/rt-ax86u-pro/helpdesk_bios?model2Name=RT-AX86U-Pro
    #28915
    Looks like just the Pro version, doesn’t apply to the 86U or 86S version? There firmware still Nov 2023
    Yes, no new firmware from what I can see for the 86U or 86S version
