› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS RT-BE96U – Official Thread New ASUS RT-BE96U Firmware version 3.0.0.6.102_34488 Version 3.0.0.6.102_34488 2024/04/23 Security: Fixed command injection vulnerability. Fixed the ARP poisoning vulnerability. Thanks to the contribution of Xin’an Zhou. Fixed code execution...
- This topic has 9 replies, 2 voices, and was last updated 2 months, 1 week ago by
- April 25, 2024 at 2:41 pm #31996
2024/04/23
Security:
Fixed code execution in custom OVPN. Thanks to the contrubution of Jacob Baines.
Fixed the injection vulnerability in AiCloud.
Fixed stack buffer overflow in lighttpd. Special thanks to Viktor Edstrom.
Fixed CVE-2023-35720, CVE-2023-48795, CVE-2023-41913
Fixed the code execution vulnerability in AiCloud. Thanks to the contribution of chumen77.
Fixed the XSS and Self-reflected HTML injection vulnerability. Thanks to the contrubution of Redfox Cyber Security.
Fixed code execution in custom OVPN.New Features:
Added Multi-link Operation (MLO) network in Guest Network Pro.
Added automatic WAN/LAN detection feature.Bug Fixes and Performance Enhancements:
Enhanced connectivity for WiFi 7 devices.
Fixed client binding issues on AiMesh nodes.
Resolved AiMesh node broadcast issues in Guest Network Pro.
Corrected Link Aggregation UI errors.
Fixed Guest Portal bugs.
Improved AiMesh system stability.
Addressed DNS errors affecting internet access for Guest Network Pro and VPN connections.
Resolved the issues of WireGuard client profile names.
Fixed dual WAN and VLAN 4094 IoT issues.https://www.asus.com/uk/supportonly/rt-be96u/helpdesk_bios/
October 24, 2024 at 12:53 pm #34623ASUS RT-BE96U Firmware version 3.0.0.6.102_37024
Version 3.0.0.6.102_37024
10/23/2024
*Please be advised that due to an architecture upgrade in AiMesh, we highly discourage downgrading to earlier firmware versions as it may result in connectivity problems. If you experience any difficulties, we suggest resetting the AiMesh router to its default settings and re-establishing the mesh connection.
Security:
Strengthened system code execution processes.
Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
Refined input validation in the web interface, ensuring a more secure web interaction environment.
Improved data export functionality in the admin portal, ensuring accurate and secure handling of client information.
Optimized memory management mechanisms, improving system stability.
Improved system buffer management, ensuring reliable data processing workflows.
Enhanced stack buffer management, promoting greater system stability.New features:
New “Network” page to consolidate main network and guest network pro for simplified management.Bug Fixes and Enhancements:
Improved AiMesh backhaul stability.
Improved system stability and fixed Guest network pro GUI issues.
Optimized memory management mechanisms, improving system efficiency and stability.In a completely sane world, madness is the only freedom (J.G.Ballard).
November 8, 2024 at 6:50 am #34780ASUS RT-BE96U Firmware version 3.0.0.6.102_37031
Version 3.0.0.6.102_37031
65.88 MB
2024/11/07Security:
Strengthened input validation and data processing workflows to further protect information security.
Enhanced device security through improved buffer handling in connection features.
Refined data handling processes, ensuring secure and accurate information management.
Enhanced file access control mechanisms, promoting a more secure operating environment.
Strengthened certificate protection, providing enhanced data security.Feature:
Increase Guest network pro mac filter to 64.
GUI bug fixes.Please unzip the firmware file, and then verify the checksum.
SHA256: d1047b81f24a22b9a920cc6dcd23472fcb600d0fc4e47ffd453ba2c39cdcdcebYou need to login in order to vote
December 7, 2024 at 10:25 am #35068New ASUS RT-BE96U Firmware version 3.0.0.6.102_37038
2024/12/03
1. Fixed internet unstable under specific conditions.
2. Improved mesh stability.In a completely sane world, madness is the only freedom (J.G.Ballard).
February 21, 2025 at 8:16 am #35666Latest ASUS RT-BE96U Firmware version 3.0.0.6.102_37812
2025/02/20
Security:
1.Enhanced input parameter handling techniques to improve data processing stability and system security.
2.Enhance system access control mechanisms.Bug Fixes and Enhancements:
1. Enhanced Client Connection Stability.
2. WPA Encryption Settings Update. Added new configuration options for WPA encryption, including the option to select AES for improved client compatibility. This setting can be found under “Network > Main Network”.
3. Improved AiMesh Backhaul Compatibility.In a completely sane world, madness is the only freedom (J.G.Ballard).
May 8, 2025 at 8:53 pm #37428ASUS RT-BE96U Firmware version 3.0.0.6.102_37839
2025/05/05
1. Improved compatibility with IoT devices on WPA2/WPA3 networks.
2. Enhanced the stability of remote connections.
3. Resolved an issue with the WiFi scheduler.
4. Improved Parental Control scheduling with support for SDN clients.
5. Fixed an issue causing Movistar IPTV to malfunction.Security fixes:
1. Implemented a security patch to address an OpenVPN issue.In a completely sane world, madness is the only freedom (J.G.Ballard).
July 19, 2025 at 5:42 am #38799ASUS RT-BE96U Firmware version 3.0.0.6.102_37849
2025/07/18
Applied Broadcom patch to resolve a potential 5 GHz Wi-Fi vulnerability that, in rare cases, could trigger temporary disconnections for connected devices; updating ensures normal operation and enhanced protection.
August 27, 2025 at 3:58 pm #39352ASUS RT-BE96U Firmware version 3.0.0.6.102_38984
2025/08/26
Security Enhancements:
– Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
– Enhanced IPsec Parameter Validation – The existing input checks have been hardened
– Detailed Audit Trails – Expanded logging within the authentication module.System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.Bug Fixes:
– Fixed abnormal client list.
– Fixed abnormal GUI behavior of Wireguard VPN.
– Fixed USB internet backup conflict with main WAN.
– Fixed abnormal WAN detection while AiDetection is enabled.
– Improved AdGuard DNS GUI issues.
– Fixed IPv6 related issues.
– Improved USB tether compatibility for pixel phones.In a completely sane world, madness is the only freedom (J.G.Ballard).
March 11, 2026 at 4:48 pm #42087New ASUS RT-BE96U Firmware version 3.0.0.6.102_39260
2026/03/11
Improvements:
– Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
– Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
– Refined accessibility-related UI and interaction details.
– Enhanced stability for 2.5G LAN/WAN port operations.
– Improved overall remote connection stability.
– Improved system behavior when using System diagnostic on feedback page.Bug Fixes:
– Fixed incorrect connection status display for certain Wi-Fi devices.
– Fixed AiMesh nodes not displayed correctly in the device list.
– Fixed a disconnection issue that occurred after enabling the MAC Filter.
– Fixed main network connectivity issue when enabling IPv6 for both the main network and GUEST NETWORK PRO.Security Enhancements:
– Strengthened input sanitization mechanism
– Enhanced system API validation for stronger protection consistency.
– Strengthened command handling and system resource access controls.
– Improved system logging and security event recording mechanisms.In a completely sane world, madness is the only freedom (J.G.Ballard).
August 6, 2026 at 2:35 pm #43132ASUS RT-BE96U Firmware version 3.0.0.6.102_39382
2026/08/06
New Features
– LED Lighting Scheduler: Added scheduling support for LED lighting , so lighting can turn on or off automatically on a custom schedule. (Available only on supported models.)
– New Time Zone Options: Added “Vancouver, Whitehorse (PST7)” and “Edmonton, Yellowknife (MST6)” time zone options for Canada.Bug Fixes and Enhancements
– Improved MAC address display logic on the WDS (wireless bridge) page, fixing cases where the band name and its MAC address were shown incorrectly.
– Fixed an issue where Client List sorting could stop working under certain conditions, and removed a duplicate wired device card in the “By Interface” view.
– Optimized the IPv6 address design for Networks.
– Improved handling of unstable network cables.
– Improved stability during the AiMesh node setup process.
– Improved IPv6 Option handling, including network connectivity after a reboot following a direct firmware upgrade in certain scenarios.
– Fixed an issue where a physical LAN port could disappear after the setup process when using the automatic WAN type detection mechanism.
– Improved AP Isolation synchronization for Networks profiles that don’t use a dedicated subnet.
– Strengthened firewall rule configuration for UPnP, improving port-forwarding stability and firewall rule restoration reliability.
– Improved Network stylesheet loading reliability.
– Fixed an issue where the URL-forwarding utility could become unresponsive after an internal network component update.Security Fixes
– Strengthened verification when a software component downloads external resources, improving connection security.
– Improved data-display handling in a web function to enhance browsing security.
– Strengthened data handling in the system logging function.We recommend upgrading to this version to maintain optimal protection.
