› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS TUF-AX5400 – Official Thread Latest firmware for TUF Gaming AX5400 (TUF-AX5400) ASUS TUF-AX5400 Firmware version 3.0.0.4.388.22525 2023/02/14 1.Fixed CVE-2022-46871 2.Fixed Client DOM Stored XSS. 3.Improved AiMesh backhaul stability. 4.Fixed AiMesh topology UI bugs. 5.Fixed...
- This topic has 5 replies, 2 voices, and was last updated 5 months, 2 weeks ago by
February 24, 2023 at 1:45 pm #22862
2023/02/14
5.Fixed the reboot issue when assigning specific clients in VPN fusion.
6.Fixed the VPN fusion bug when importing the Surfshark WireGuard conf file.
7.Fixed network map bugs.You need to login in order to vote
May 26, 2023 at 1:22 pm #24750Latest firmware for TUF Gaming AX5400 (TUF-AX5400)
ASUS TUF-AX5400 Firmware version 3.0.0.4.388.23285
Release date: 2023/05/18
New features:
-Built-in Surfshark in VPN Fusion allows you to surf the internet anonymously and securely from anywhere by encrypting connections. Please refer to https://asus.click/SurfsharkVPN-iPhone/Android USB auto backup WAN allows you to connect your phone to the router’s USB port and use it as an internet source. Please refer to https://asus.click/AutobackupWAN
-DDNS transfer allows you to transfer your ASUS DDNS hostname from your original router to the new one. Please refer to https://asus.click/ASUSDDNS
-Fixed the AiCloud login issue after unplugging and plugging the HDD into the USB port.
-Modified the USB application option text in dual WAN.
-Allowed WireGuard Server clients to access the Samba server.
-Fixed memory leak issue.
-Enabled the failback function when using the iOS/Android USB backup WAN.
-Resolved the issue where the USB path is not displayed on the Media Server page in the AiMesh nodeSecurity updates:
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group – cse hkust contribution.
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.You need to login in order to vote
October 14, 2023 at 8:24 pm #27526Latest ASUS TUF-AX5400 Firmware version 3.0.0.4.388_24121
Version 3.0.0.4.388_24121
2023/10/09
Bug Fixes and Enhancements
– Fixed WAN Connection Issue.
– Fixed cannot access WireGuard Server if enable DMZ.
– Fixed DDNS server error occurs when registering DDNS with app.
– NowTV profile has been added under new IPTV profiles.
– IPTV settings have been updated for better compatibility with Unifi Biz VoIP service.
– Fixed v6plus-Related Issues and.
– Resolved OpenVPN Server TAP Mode Issue.
– Fixed ipv6 network service filter not work.
– Fixed the problem that the Aicloud app cannot add router on Android 9.Security Fixes
– Fixed several curl vulnerabilities including CVE-2021-27218, CVE-2021-27219, CVE-2023-28322, CVE-2023-28321, CVE-2023-28319, CVE-2023-32643.
– Fixed FFmpeg vulnerabilities, specifically CVE-2022-3964, CVE-2022-48434, and CVE-2022-3109.
– Corrected an OpenVPN vulnerability categorized as CWE-134.
– Strengthened protection against SSH brute force attacks.
– Updated OpenSSL to 1.1.1t for vulnerabilities.You need to login in order to vote
November 22, 2024 at 10:44 pm #34970ASUS TUF-AX5400 Firmware version 3.0.0.4.388_24194
Version 3.0.0.4.388_24194
95.58 MB
2024/11/221. Strengthened input validation and data processing workflows to further protect information security.
6. Strengthened certificate protection, providing enhanced data security.Please unzip the firmware file, and then verify the checksum.
SHA256: 02780620cea355b5c387ee08a794fd897283756122081d82e03128764b3ce217You need to login in order to vote
April 16, 2026 at 4:40 pm #42414TUF-AX5400 firmware version 3.0.0.4.388_24356
2026/04/16
Improvements:
- Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v.
- Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
- Refined accessibility-related UI and interaction details.
- Improved overall remote connection stability.
Security Enhancements:
- Strengthened input sanitization mechanism.
- Enhanced system API validation for stronger protection consistency.
- Strengthened command handling and system resource access controls.
- Improved system logging and security event recording mechanisms.
May 12, 2026 at 2:13 pm #42685ASUS TUF-AX5400 Firmware version 3.0.0.4.388_24358
2026/05/12
Security Fixes:
– Enhanced system security by addressing an unsafe remote script execution mechanism in.
– Improved system security by addressing a heap buffer overflow vulnerability during cache handling.
– We recommend upgrading to this version to ensure up-to-date protection.You need to login in order to vote
