Asus ZenWiFi drops network connection I’m having an issue when a Lightroom Classic plugin tries to connect to a URL in order to upload images. Lightroom reports a “networkConnectionLost” error and refuses to upload the…
UKTH forums 💻 Computers Networking Asus ZenWiFi drops network connection I’m having an issue when a Lightroom Classic plugin tries to connect to a URL in order to upload images. Lightroom reports a “networkConnectionLost” error and refuses to upload the...
  • #40343
    Jim W
    • Replies 3
    I’m having an issue when a Lightroom Classic plugin tries to connect to a URL in order to upload images. Lightroom reports a “networkConnectionLost” error and refuses to upload the images.
    When I connect the computer <u>directly</u> to the cable modem the problem doesn’t happen, so it seems clear that the router is the issue.
    The computer is near the main node, not the mesh node.
    Here are the details of my environment:
    • Mac mini running MacOS Tahoe 26.1 (25B78)
    • Lightroom Classic 15.0.1
    • Asus ZenWiFi AX (XT8 V1) running 3.0.0.4.388_24710
      • Adaptive QoS is off.
    I put an excerpt from the MacOS log files here, in case it helps point to the root cause: https://www.dropbox.com/scl/fi/kvqa…-Log.rtf?rlkey=rps8velglrl9c819l0dqth2tn&dl=0
    Have you experienced anything similar, or do you have suggestions for troubleshooting / resolving this issue?
    Thanks,
    Jim
