- This topic has 0 replies, 1 voice, and was last updated 6 years, 10 months ago by .
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUSWRT-Merlin Third Party Addons – 384.15 I was browsing GitHub and noted RMerlin is working his magic for the developers community Taken from – https://github.com/RMerl/asuswrt-merlin/wiki/Addons-API Third party addons Starting with 384.15, Asuswrt-Merlin now supports web integration...
I was browsing GitHub and noted RMerlin is working his magic for the developers community ![]()
Third party addons
Starting with 384.15, Asuswrt-Merlin now supports web integration for third party addons. Up to a maximum of five custom pages can be added at any location on the webui.
There is also a dedicated settings storage for addons, separate from nvram, and therefore not bound to its limitations (i.e. you can create new settings without having to recompile a firmware image).
Locations
The /jffs/addons/ directory is the standard location. You should create a directory there to store all your files.
The user-defined settings for all addons will be stored in /jffs/addons/custom_settings.txt.
Custom pages
The firmware supports up to five custom pages. These pages should be mounted at boot time through a script, which should ideally be called from services-start. You should put your custom page in the /jffs/addons/my_addon/ folder along with the install script. Here is a sample of an install script, which will also insert your page as a new tab in the Tools section.
Follow below link for more details ……….
