› UKTH forums › Wireless Routers & Modems › AVM & Wireless › AVM Fritz!Box 6850 LTE – Official Thread AVM Fritz!Box 6850 LTE – Hardware Specs CPU: Dakota @ 717 MHz – ARM Cortex A9 – 4 x CPU-Cores RAM Size: 512 MB Flash Size: 512 MB Ethernet Port...
- This topic has 2 replies, 2 voices, and was last updated 3 years, 10 months ago by
Grisu.
January 16, 2023 at 5:57 pm #22430
- CPU: Dakota @ 717 MHz – ARM Cortex A9 – 4 x CPU-Cores
- RAM Size: 512 MB
- Flash Size: 512 MB
- Ethernet Port Count: 4 x 1GbE-LAN
Technical specifications:
- Mini SIM slot (LTE 4G) category 4 modem)
- IP-based telephony
- 4 x gigabit LAN ports
- Wireless access point compliant with IEEE 802.11ac, n, g, a
- 1 x high-speed USB port for storage devices and printers
- Integrated DECT base station for up to six cordless telephones
- 1 a/b port (either TAE or RJ11) for an analog telephone, answering machine or fax
Wi-Fi:
- Wi-Fi 5 (up to 866 Mbit/s gross, 5 GHz) and 4 (up to 400 Mbit/s gross, 2.4 GHz)
- Secure upon delivery with WPA2 encryption, WPA3/2 transition mode is also available
January 16, 2023 at 6:00 pm #22431Latest FRITZ!Box 6850 LTE firmware FRITZ!OS 7.29
Release date: 12/03/2021
Download:
http://ftp.avm.de/fritzbox/fritzbox-6850-lte/other/fritz.os/
**Top functions of FRITZ!OS**
————————————————————– Priority for working from home – Easy to enable prioritization of a computer for internet access
– Improved SMS function – Send function for SMS and Journal for received and sent SMS
– FRITZ!Fon displays weather forecast on the start screen (currently only available for germany)
– FRITZ! Smart Home now supports DECT compatible roller shutters
– Smart Home: Lightsequence “Wakeup/Sleep” for FRITZ!DECT 500 and compatible DECT LEDs
– Smart Home: TOP – Perfect indoor climate with FRITZ!DECT 440 – humidity information at a glance
– For FRITZ!Box’s integrated fax machine: Log of received and sent faxes
– Telephony: TOP – Many improvements to user interface for using the telephone book, call diversion and call blocks————————————————————
With each FRITZ!OS update, AVM also updates its security functions. Therefore we recommend performing the update for all devices.
Note: Instructions for configuring and using Mesh functions are presented at en.avm.de/mesh-faq
Below you find a complete list and descriptions of the new functions in the latest FRITZ!OS, along with a list of further improvements in this version.
http://ftp.avm.de/fritzbox/fritzbox-6850-lte/other/fritz.os/info_en.txt
January 16, 2023 at 10:11 pm #22432Latest Fritz!Lab beta-firmware: https://en.avm.de/fritz-lab/fresh-from-development/fresh-from-development/
https://en.avm.de/fileadmin/user_upload/DE/Labor/Download/fritzbox-6850_lte-labor-101708.zip
Download information:
Language: Multi-language
Version: 7.39-101708
Date: 29 November 2022You need to login in order to vote
