› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS RT-AX5400 – Official Thread
- This topic has 6 replies, 2 voices, and was last updated 2 minutes ago by
September 16, 2024 at 8:21 am #33886
Version 3.0.0.4.388_25058
48.25 MB
2024/08/30Bug Fixes and Enhancements:
– Improved AiMesh backhaul stability for a more reliable connection.
– Enhanced WireGuard performance for smoother VPN connections.
– Optimized memory utilization and resolved occasional server errors when registering DDNS with an app.
– Fixed the time display issue for the preferred upgrade time in the Auto Firmware Upgrade function.
– Fixed an issue that caused hostname errors in the DDNS service.
– Resolved IPv6 network service filter issues.
– Addressed an issue causing HTTPD crashes.Security Updates:
– Enhanced the import process for WireGuard client configurations.
– Enhanced protection against SSH brute force attacks.
– Strengthened protection for credentials.
– Addressed XSS and self-reflected HTML injection
– Addressed DoS vulnerabilities in the HTTPD and firewall configuration pages.
– Fixed an information disclosure vulnerability.
– Resolved Client DOM Stored XSS issues.You need to login in order to vote
October 17, 2024 at 10:20 pm #34566ASUS RT-AX5400 Firmware version 3.0.0.4.388_25119
Version 3.0.0.4.388_25119
48.25 MB
2024/10/161. Strengthened system code execution processes.
3. Refined input validation in the web interface, ensuring a more secure web interaction environment.
4. Improved data export functionality in the admin portal, ensuring accurate and secure handling of client information.
5. Optimized memory management mechanisms, improving system stability.
6. Improved system buffer management, ensuring reliable data processing workflows.
7. Enhanced stack buffer management, promoting greater system stability.Please unzip the firmware file, and then verify the checksum.
SHA256: d155df280e4e64cea5efef8468a6b9eeec6038fd73f0ee73a2cea1c4ee0ec694You need to login in order to vote
November 8, 2024 at 6:15 am #34770ASUS RT-AX5400 Firmware version 3.0.0.4.388_25127
Version 3.0.0.4.388_25127
48.3 MB
2024/11/061. Strengthened input validation and data processing workflows to further protect information security.
6. Strengthened certificate protection, providing enhanced data security.Please unzip the firmware file, and then verify the checksum.
SHA256: 1cc7d3206cfbd89a54a099a973d9c44a279b55144c7bd97f25d99445ade19e7dYou need to login in order to vote
February 15, 2025 at 8:43 am #35628Latest ASUS RT-AX5400 Firmware version 3.0.0.4.388_25137
2025/02/14
2. Fixed client binding issues in Mesh scenarios.You need to login in order to vote
August 29, 2025 at 6:49 am #39371ASUS RT-AX5400 Firmware version 3.0.0.4.388_25192
2025/08/27
Security Enhancements:
– Password Policy Upgrade – Minimum 10 characters with at least 1 letter, 1 digit and 1 special symbol, and no consecutive identical characters; hardens defense against brute-force attacks.
– Enhanced IPsec Parameter Validation – The existing input checks have been hardened
– Detailed Audit Trails – Expanded logging within the authentication module.System Improvements:
– Client List Maintenance – Resolved an issue that prevented offline devices from being removed from the client list.Bug Fixes:
– Fixed abnormal client list.
– Fixed abnormal GUI behavior of Wireguard VPN.
– Fixed USB internet backup conflict with main WAN.
– Fixed abnormal WAN detection while AiDetection is enabled.
– Improved AdGuard DNS GUI issues.
– Fixed IPv6 related issues.
– Improved USB tether compatibility for pixel phones.You need to login in order to vote
October 21, 2025 at 5:27 pm #39892ASUS RT-AX5400 Firmware version 3.0.0.4.388_25204
2025/10/20
– Enhanced system stability.
– Mitigated security risks in AiCloud service by enforcing strict credential verification, implementing robust file path validation, and hardening command execution logic to prevent unauthorized access and manipulation of system resources.
– Fixed an issue that allowed certain user settings to be bypassed, improving overall user control and protection.You need to login in order to vote
November 25, 2026 at 6:54 am #45226ASUS RT-AX5400 Firmware version 3.0.0.4.388_25395
2026/11/24
Bug Fixes.
Fixed an issue that prevented the device selection screen from opening in VPN Fusion.Security Fixes.
Enhanced the security of system text data processing.
Strengthened data processing mechanisms in cloud connection services.
Improved the processing of name resolution data in cloud connection components.
Fixed security issues in cloud connection components.
Fixed a security issue in the firmware.
Strengthened access controls for diagnostic data.
Improved encryption key handling in the management interface.
Enhanced the security of encrypted data processing in the management interface.
Strengthened access protection for VPN connection keys.
Strengthened login session validation in the management interface.
Strengthened access controls for network traffic processing services.
Strengthened data processing for OpenVPN client settings.
Strengthened validation of DDNS settings data.
Strengthened processing of IPsec VPN settings data.
Strengthened validation of OpenVPN custom settings.
Strengthened data processing for Multi-WAN routing settings.
Strengthened authentication and key protection between AiMesh nodes.
Improved authentication mechanisms for external connections.
Strengthened request handling in the management interface to improve service stability.
Strengthened file access controls when processing compressed files.
Strengthened access protection for routing services under specific ISP settings.
Strengthened input data processing mechanisms in the firmware.
Strengthened data validation when importing VPN settings.
Strengthened data processing for QoS bandwidth limiter settings.
Strengthened data processing for cloud service settings.
Adjusted key management mechanisms.
Strengthened validation of IPsec VPN connection profile names.
Strengthened validation mechanisms for OpenVPN configuration directives.We recommend updating to this version to maintain optimal protection.
