Critical Alert for Brother Device Owners Security researchers at Rapid7 have uncovered eight serious vulnerabilities affecting 689 Brother models, including printers, scanners, and label makers. These flaws also impact select devices from Fujifilm, Ricoh, Toshiba, and…
› UKTH forums › Computers › Printers & Scanners › Critical Alert for Brother Device Owners Security researchers at Rapid7 have uncovered eight serious vulnerabilities affecting 689 Brother models, including printers, scanners, and label makers. These flaws also impact select devices from Fujifilm, Ricoh, Toshiba, and...
  • #38150
    • Replies 8,740
    Security researchers at Rapid7 have uncovered eight serious vulnerabilities affecting 689 Brother models, including printers, scanners, and label makers. These flaws also impact select devices from Fujifilm, Ricoh, Toshiba, and Konica Minolta, bringing the total to 748 affected models.
    Key Vulnerability: CVE-2024-51978
    • Severity: 9.8 (Critical)
    • Issue: Attackers can derive the default admin password using the device’s serial number.
    • Impact: Remote takeover of the device and potential access to connected systems.
    • Fix: Cannot be fully patched via firmware—requires a manufacturing process change.
    Other Vulnerabilities Include:
    CVE ID Description CVSS Score Access Level
    CVE-2024-51977 Leak of sensitive information via HTTP/IPP 5.3 Unauthenticated
    CVE-2024-51979 Stack-based buffer overflow 7.2 Authenticated
    CVE-2024-51980 Forced TCP connection 5.3 Unauthenticated
    CVE-2024-51981 Arbitrary HTTP request execution 5.3 Unauthenticated
    CVE-2024-51982/83 Device crash via PJL or HTTP 7.5 Unauthenticated
    CVE-2024-51984 Disclosure of external service passwords (e.g., LDAP, FTP) 6.8 Authenticated
    What You Can Do
    • Change the default admin password immediately.
    • Check if your model is affected using.
    • Apply firmware updates where available—seven of the eight vulnerabilities have patches.
    • For CVE-2024-51978, only newly manufactured devices will be fully protected.
    https://www.rapid7.com/blog/post/multiple-brother-devices-multiple-vulnerabilities-fixed/
    • This topic was modified 1 year, 4 months ago by UK SentinelUK Sentinel.
