› UKTH forums › 📺 White & Brown Goods › DishWashers › Dishwasher’s not draining water We moved into a house and inherited a bosch dishwasher, but it didnt drain water out, had it checked and they said it wasn’t worth spending money on possible parts...
- This topic has 3 replies, 3 voices, and was last updated 3 years, 1 month ago by
mjones0788.
- September 19, 2023 at 7:19 pm #27030
We moved into a house and inherited a bosch dishwasher, but it didnt drain water out, had it checked and they said it wasn’t worth spending money on possible parts needed. Bought a replacement dishwasher and its doing exactly the same thing!
So must be the way we’re draining water?
Attached a picture of the setup uncerneath the sink, waste pipe is going into the opposite side to the washing machine, which weve never had an issue with.
Any help would be great!
Thank you
September 19, 2023 at 8:33 pm #27038Welcome, looking at you picture of the P-Trap With 2 x washing machine type waste pipe spigot connections.
I would first investigate if there is a fat build up in the trap, does the sink plug / drain smell ? maybe worth unscrewing P-trap from bottom of sink and see if there is any signs of blockage etc.
Then if possible, disconnect dishwasher drain hose from trap waste spigot and place the end in a bucket at ground level and see if the dishwasher then drains when operated (short cycle).
It is tricky to diagnose, but it does look as though the trap ‘main’ drain hose is rather high and may need lowering to aid drainage and also check to see if the Dishwasher hose has one or many high points (loop), it should only have one in practice as drainage water could be feeding back into the dishwasher from the water stored in dishwasher drainage hose.
Washing machines drain pumps can be stronger than dishwasher pump, so may explain why no issues with washing machine.
Pic courtesy of homeinspectiongeeks.com
September 19, 2023 at 9:29 pm #27041Just demount everything and clean it.
If ok the
constipationobstruction is afterwards in the wall, then it my get more expensive to clean.You need to login in order to vote
September 20, 2023 at 9:29 pm #27054That’s great. Thanks for the advice. Will have a look when I get home.
thank you!
