Draytek DDNS Does anyone know how you remove a letsencrypt cert from a Draytek 2862 router. i’ve removed it on the router but the ACME log still says it’s valid.
UKTH forums 🛜 Wireless Routers & Modems DrayTeK & Wireless Draytek DDNS Does anyone know how you remove a letsencrypt cert from a Draytek 2862 router. i’ve removed it on the router but the ACME log still says it’s valid.
  • #15024
    Avatarkzin
    • Replies 3
    #15025
    • Replies 8,669
    After you removed the  letsencrypt cert – did you reboot Draytek 2862 ?
    Then go to [SSL VPN] > [General Setup] and see if the DrayDDNS certificate is still there ?
    Edit: Certs are valid until they expire, but they do not have to be used.
    Removing the certs is an interesting question, I will have a look at my Vigor and let you know
    #15028
    • Replies 8,669
    So you have probable done this already,  have a look under Main Menu > Certificate Management, is the Letsencrypt Cert there ? if so It should be removable.
    #15035
    Avatarkzin
    • Replies 3
    Hmm, I did a reboot after updating the firmware last night and when i look at the dynamic dns setting its says the lets encrypt cert is empty.what it does say when i view the log in the DNS settings is below but i suppose the doesnt actually say its live just that the status of the DNS was successful i assume?
    2021-09-03 19:17:03 send certificate status to myvigor
    2021-09-03 19:17:03 Update certificate status successfully.
    #15036
    • Replies 8,669
    Sometime logs are over helpful ;-)
    #15039
    Avatarkzin
    • Replies 3
    It says no certs at all in certificate management.
    i’m beginning to wonder if the info i’m being given is incorrect. our phone system engineers think there’s a cert on the router which is why our phone system is playing up.
    Thanks for checking for me, i’ll revisit again tomorrow.
    #15040
    • Replies 8,669
    Sounds like a factory reset of the DrayTeK 2862 maybe in order, just to make sure no certs remain or corruption has occurred.
    alas unsure how complicated you set-up is etc ?
