iPhone Unexplained High Data Usage System Services While Roaming and Abroad If you have noticed that for some odd reason you are experiencing unexplained High iPhone Data Usage System Services while on Wifi, roaming and abroad, with no obvious app culprit….
UKTH forums 📱 Mobile iPhones iPhone Unexplained High Data Usage System Services While Roaming and Abroad If you have noticed that for some odd reason you are experiencing unexplained High iPhone Data Usage System Services while on Wifi, roaming and abroad, with no obvious app culprit....
  • #35268
    • Replies 8,674
    Maybe worth while checking if the option to Share Analytics is turned off.
    This is particularly relevant if you are running a developer beta where analytics is on by default!.
    Settings > Privacy & Security > Analytics & Improvements > Share Analytics = Off
    Another way to check if daily log files are being sent is go to …
    Settings > Privacy & Security > Analytics & Improvements > Analytics Data >  (logs)
