- This topic has 1 reply, 1 voice, and was last updated 1 year, 6 months ago by .
› UKTH forums › 🎧 PC & Laptop Gaming › Gaming Desktops › Intel has finally tracked down the problem making 13th- and 14th-gen CPUs crash For several months, Intel has been investigating reports that high-end 13th- and 14th-generation desktop CPUs (mainly, but not exclusively, the Core i9-13900K and 14900K) were crashing during gameplay. Intel partially...
For several months, Intel has been investigating reports that high-end 13th- and 14th-generation desktop CPUs (mainly, but not exclusively, the Core i9-13900K and 14900K) were crashing during gameplay. Intel partially addressed the issue by insisting that third-party motherboard makers adhere to Intel’s recommended default power settings in their motherboards, but the company said it was still working to identify the root cause of the problem.
The company announced yesterday that it has wrapped up its investigation and that a microcode update to fix the problem should be shipping out to motherboard makers in mid-August “following full validation.” Microcode updates like this generally require a BIOS update, so exactly when the patch hits your specific motherboard will be up to the company that made it.
CONT’D.
If you’re using a 13th- or 14th-generation CPU and you’re not noticing any problems, the microcode update should prevent your processor from degrading. But if you’re already noticing stability problems, Tom’s Hardware reports that “the bug causes irreversible degradation of the impacted processors” and that the fix will not be able to reverse the damage that has already happened.
There has been no mention of 12th-generation processors, including the Core i9-12900K, suffering from the same issues. The 12th-gen processors use Intel’s Alder Lake architecture, whereas the high-end 13th- and 14th-gen chips use a modified architecture called Raptor Lake that comes with higher clock speeds, a bit more cache memory, and additional E-cores.
