ASUS EBM68 Firmware version 3.0.0.6.102_46374 – 2026/05/20 ASUS EBM68 Firmware version 3.0.0.6.102_46374 2026/05/20   Bug Fixes and Enhancements – Improved WiFi roaming behavior to reduce temporary disconnections in some scenarios. – Improved roaming compatibility for certain client…
› UKTH forums › Wireless Routers & Modems › ASUS & Wireless › ASUS EBM68 Firmware version 3.0.0.6.102_46374 – 2026/05/20 ASUS EBM68 Firmware version 3.0.0.6.102_46374 2026/05/20   Bug Fixes and Enhancements – Improved WiFi roaming behavior to reduce temporary disconnections in some scenarios. – Improved roaming compatibility for certain client...
RELEASE
  • #42720
    2026/05/20
    – Improved roaming compatibility for certain client devices.
    – Improved App Remote Connection stability in certain scenarios to prevent unexpected connection drops.
    – Improved AiMesh onboarding reliability, addressing cases where the onboarding process could stall and fail to complete.
    – Fixed an issue where the guest network client list might not display correctly in certain scenarios.
    – Fixed an issue with Web history display.
    – Fixed an issue where the app could not remove offline devices.
    – Fixed an issue where specific IPv6 configuration flows could cause IPv6 connectivity problems on the main network.
    – Fixed an issue where enabling System Diagnostics and staying on a specific page could cause repeated reboots.
    – https://portal.expertwifi.net/ is now supported, by accessing portal, you won’t need to download windows or mac utility to access sites remotely.
    Security Fixes
    – Enhanced input validation and protection to reduce the risk of command injection and SQL injection.
    – Hardened environment variable handling.
    – Hardened protections around specific logging/command composition flows to reduce potential injection risks.
    – Patched a command injection risk in a specific network diagnostic function.
    – Enhanced DNS name handling to address a potential memory issue that could occur in rare cases during name format conversion, improving system security and robustness.
    – Improved safeguards for execution modules to reduce the risk of substitution during certain processes.
    We recommend upgrading to this version to maintain best protection.
    https://www.asus.com/uk/supportonly/ebm68/helpdesk_bios/
