› UKTH forums › 🛠️ Life & Stuff › Garden and Shed › New Ryobi One+ OLM1833B Cordless 33cm Lawn Mower First Look
- This topic has 3 replies, 2 voices, and was last updated 1 year, 8 months ago by
- June 11, 2024 at 6:06 pm #32513
We recently purchased the Ryobi One+ OLM1833B Cordless 33cm lawn mower and though to create a simple review with a few pictures.
The Ryobi One+ OLM1833B was purchased via the RYOBI direct online store for £159 (without battery).
Assembly only took around 10 minutes and we have other Ryobi tools, so did not need the extra batteries.
Ryobi One+ OLM1833B Battery compartment with RED Fuse Key.
After first grass cut there was minimal grass trimmings sticking to underside. It had rained the night before so grass was a little damp.
Picture of how well the RYOBI EasyEdge™ works cutting the grass at the borders.
Picture of Grass Trimming (not Mulching) showing how well short / fine the Ryobi One+ Lawn Mower cuts the grass.
The RYOBI Lawn Mower also came with a Mulching plug to block the chute to the grass bag, this then converts the lawnmower it into a mulching mower which can be handy.
June 11, 2024 at 6:07 pm #32514The Ryobi One+ OLM1833B Cordless 33cm Lawn Mower is a good little mower and ideally suited for small to medium gardens, the electric motor was quite and omitted a high pitch motor noise.
Cutting the grass was easy and the Ryobi One+ was easily moved around the garden, the grass catcher capacity was good.
Alas the Ryobi One+ EasyEdge™ did not work as well as I had hoped and I still needed to use an edge trimmer, I also found the wheel height adjustment rather fragile / flimsy to adjust.
But for £159, a great little grass cutter
June 11, 2024 at 8:36 pm #32517Thanks, not too bad then. My lawnmower doesn’t cut near the edges either so i just use a strimmer to go along and cut that part.
June 11, 2024 at 8:44 pm #32518Seems that 38 and 40 V Battery lawnmowers are all the rage at the moment, but this Ryobi One+ OLM1833B is a great little grass cutter and at a realistic price
