ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58403 – 2026/02/24 ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58403 Version 3.0.0.6.102_58403 2026/02/24 Improvements: – Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v. – Improved Wi-Fi roaming compatibility and stability…
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58403 – 2026/02/24 ASUS ZenWiFi BT6 Firmware version 3.0.0.6.102_58403 Version 3.0.0.6.102_58403 2026/02/24 Improvements: – Optimized Wi-Fi roaming stability for devices supporting 802.11k but not allowing 11v. – Improved Wi-Fi roaming compatibility and stability...
RELEASE
  • #41966
    2026/02/24
    Improvements:
    – Improved Wi-Fi roaming compatibility and stability for iOS 26 devices.
    – Refined accessibility-related UI and interaction details.
    – Improved overall remote connection stability.
    – Improved system behavior when using System diagnostic on feedback page.
    – Optimized LED accuracy for AiMesh Ethernet onboarding status.
    – Fixed temporary disconnections during client roaming via roam-assist.
    Bug Fixes:
    – Fixed connection failures when using 5GHz 160MHz bandwidth.
    – Fixed an issue preventing 5G WPS from enabling correctly.
    – Fixed connectivity issues with NOW TV after configuration.
    – Fixed incorrect connection status display for certain Wi-Fi devices.
    – Fixed AiMesh nodes not displayed correctly in the device list.
    – Fixed a disconnection issue that occurred after enabling the MAC Filter.
    – Fixed main network connectivity issue when enabling IPv6 for both the main network and Smart Home Network.
    Security Enhancements:
    – Enhanced system API validation for stronger protection consistency.
    – Strengthened command handling and system resource access controls.
    – Improved system logging and security event recording mechanisms.
    https://www.asus.com/networking-iot-servers/whole-home-mesh-wifi-system/zenwifi-wifi-systems/asus-zenwifi-bt6/helpdesk_bios?model2Name=ASUS-ZenWiFi-BT6
