› UKTH forums › 🛜 Wireless Routers & Modems › NetGear & Wireless › Netgear Nighthawk RAXE500 (AXE11000 ) – Official Thread At CES 2021, Netgear announced its first Wi-Fi 6E-ready device that takes full advantage of the 6GHz band: the Nighthawk RAXE500, a $599.99 tri-band wireless router. Wi-Fi 6E wireless routers...
- This topic has 4 replies, 1 voice, and was last updated 1 year, 2 months ago by
- February 11, 2021 at 8:58 pm #11904
Wi-Fi 6E wireless routers like this one broadcast over the 6GHz band, in addition to serving the 2.4GHz and 5GHz bands that most devices can use. A number of devices launching at CES 2021 will support Wi-Fi 6E, and as a result, routers like the new Nighthawk RAXE500 can provide unfettered bandwidth to devices that require a lot of it. Not just that, devices connected via 6GHz can avoid disruptions from the many other household devices (even those being used by nearby neighbors) that operate on the crowded 2.4GHz and 5GHz bands.
Netgear’s new high-end router looks like a manta ray, which is to say it’s relatively par for the course for the Nighthawk line of wireless routers. Looks aren’t everything, though — the router should provide some very fast AXE11000 Wi-Fi signals. Netgear claims that this device can push beyond gigabit speeds for mobile devices, and that it has a total throughput of 10.8Gbps over wireless.
The new Nighthawk features five gigabit ports and two USB 3.0 ports on its rear. It supports multi-gigabit speeds via a compatible DOCSIS 3.1 modem, either through the RAXE500’s single 2.5Gb link or by opting for a multiport link aggregation method (which offers up to 2Gbps speeds).
October 31, 2022 at 7:29 pm #21490Latest RAXE500 Firmware Version 1.0.9.78
Last Updated:02/10/2022
New Features:
- Support for DHCP options 60 and 61 in the European SKU
- Router login access when DoH (DNS over HTTPS) is enabled
- Administrator login is blocked after consecutive incorrect password entries
Security Fixes:
- Fixes security vulnerabilities.
Bug Fixes:
- Improves stability
- Fixes Nest Camera “random disconnect” issue
Download Link: https://www.downloads.netgear.com/files/GDC/RAXE500/RAXE500-V1.0.9.78_2.0.38.zip
January 24, 2023 at 4:27 pm #22484Latest RAXE500 Firmware Version 1.0.10.86
Last Updated: 12/13/2022
New Features:
Supports SpeedTest sever manual select list
Supports HK, UAE Wi-Fi country optionsSecurity Fixes:
Bug Fixes:
Fixes IEEE 802.3ad can not establish connections issue.
Fixes new USB folder created with admin not working issue.Download Link: https://www.downloads.netgear.com/files/GDC/RAXE500/RAXE500-V1.0.10.86.zip
February 23, 2023 at 3:33 pm #22858Latest RAXE500 Firmware Version 1.0.12.96
Last Updated:01/02/2023
Bug Fixes:
- Fixes the issue where a configuration through the router web interface causes a port conflict.
- Fixes the issue where the router web interface shows that the guest WiFi network is active even though you set up a WiFi schedule that specifies that the guest WiFi network must be inactive during that time.
- Fixes the issue where the router has low throughput when QoS is enabled.
- Fixes the issue where you cannot use the Nighthawk app to pause or restart parental controls for a client if you already blocked the client in the router web interface.
- Fixes the issue where you might be unable to select certain 5 GHz channels if the country setting is Australia.
- Fixes the issue where the router can’t send the log via Outlook.
- Fixes the issue where the router does not send the log if you configure the option to send the log when it is full.
- Fixes the issue where all Ethernet LAN ports go down if you change the Internet subnet mask.
- Fixes the issue where the link aggregation options are masked in the router web interface when the router functions in access point (AP) mode.
- Fixes the issue where the router web interface shows a warning message when you select port 1 or the Multi-Gig port in VLAN bridge mode.
- Fixes the issue where admin password protection is not enabled by default for ReadyShare HTTPS (via Internet) and FTP (via Internet).
- Fixes the issue where access point (AP) mode is not masked in the router web interface when WAN aggregation is enabled.
- Fixes the issue where the router web interface doesn’t show MAC address information on the Attached Devices page when QoS is enabled
- Fixes the issue where the router web interface displays an incorrect text format.
- Fixes the issue where the router allows the user name and password for PPPoE to be longer than 63 characters.
Security Fixes:
Known Issues:
- The Nighthawk app and router web interface don’t successfully complete the OOKLA speed test in PPPoE mode, but the speed test does work normally if you run it from the OOKLA web portal or OOKLA app.
- Clients cannot connect to the 2.4 GHz band if it functions with a 40 MHz channel width.
https://kb.netgear.com/000065500/RAXE500-Firmware-Version-1-0-12-96
July 15, 2025 at 2:59 pm #38547New RAXE500 Firmware Version 1.2.14.114
Version 1.2.14.114
07/10/2025
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security.
https://kb.netgear.com/000067272/RAXE500-Firmware-Version-1-2-14-114
