Openreach Deploy G.INP to Boost UK ECI FTTC Broadband Lines News! Openreach (BT) has finally succeeded in deploying ReTransmission (ReTx / G.INP) across their ECI (Ribbon) based UK estate of Fibre-to-the-Cabinet (FTTC / VDSL2) broadband ISP cabinets and customer lines,…
› UKTH forums › Broadband Tech & ISP’s › BT › Openreach Deploy G.INP to Boost UK ECI FTTC Broadband Lines News! Openreach (BT) has finally succeeded in deploying ReTransmission (ReTx / G.INP) across their ECI (Ribbon) based UK estate of Fibre-to-the-Cabinet (FTTC / VDSL2) broadband ISP cabinets and customer lines,...
  • #32541
    • Replies 8,749
    News!
    Openreach (BT) has finally succeeded in deploying ReTransmission (ReTx / G.INP) across their ECI (Ribbon) based UK estate of Fibre-to-the-Cabinet (FTTC / VDSL2) broadband ISP cabinets and customer lines, which comes after many years of trying to get the technology to work. The result is faster speeds and improved stability.
    The news these days is typically dominated by deployments of full fibre (FTTP) broadband lines, which makes it easy to forget that around 15 million lines are still using Openreach’s previous hybrid-fibre (FTTC) technology, and so any developments on this front remain very important.
    Source
