Samsung Heat Pump Dryer Fault Codes Fault Codes for the Samsung Heat Pump Dryer – DV9 and DV8 Series (as a guide)   Error CodeΒ  Β  Β  Β Fault Description tC –Β  Β  Β  Β  Β  Β …
UKTH forums πŸ“Ί White & Brown Goods Tumble Dryers Samsung Heat Pump Dryer Fault Codes Fault Codes for the Samsung Heat Pump Dryer – DV9 and DV8 Series (as a guide)   Error CodeΒ  Β  Β  Β Fault Description tC –Β  Β  Β  Β  Β  Β ...
  • #11853
    • Replies 8,664
    tC –Β  Β  Β  Β  Β  Β  Β Air Temperature Sensor Check
    tC5 –Β  Β  Β  Β  Β  Compressor temperature Sensor Check
    dC –Β  Β  Β  Β  Β  Β Running the dryer with door open
    HC –Β  Β  Β  Β  Β  Compressor Overheat
    9C2 –Β  Β  Β  Β  Β It occurs when low voltage is detected
    5C –Β  Β  Β  Β  Β  The Water tank is full or Water pump is out of order
