Server Downtime Every Morning Since Migration So for the last two morning since the server migration, the UKTechHub website has been offline in the morning for an hour or so. Currently in communication with Hosting company…
› UKTH forums › UKTechHub News & Information › Server Downtime Every Morning Since Migration So for the last two morning since the server migration, the UKTechHub website has been offline in the morning for an hour or so. Currently in communication with Hosting company...
Viewing 15 posts - 1 through 15 (of 22 total)
  • #33552
    • Replies 8,727
    Currently in communication with Hosting company to try to resolve issue
    #33575
    Was still down this morning, just notice it come back now
    • Replies 8,727
    Thanks, having problems finding route cause
    #33585
    If helps, error I got was database connection error but I didn’t copy the exact text.
    Is the DB on a separate box or the same? Is there any scheduled maintenance i.e. backup that’s been incorrectly configured or taking a long time to run as that can lock the DB until finished?
    • Replies 8,727
    Thanks, the messages I received was ‘Error establishing a database connection’.
    Its a WordPress related dB, alas only plugin I installed since migration was LSCache which is a caching plugin.
    I have set the Cache options for tonight to minimal to see if issue occurs again in the morning, if it does then I will have to disable LSCache and see if this is the root cause.
    Issue is causing CPU’s to max out which then causes server to fail.
    #33587
    Fingers crossed for tomorrow morning
    No issues at all and faster than ever before!
    Even submit answer is fast now, ~3s.
    • This reply was modified 2 years, 2 months ago by GrisuGrisu.
    #33594
    • Replies 8,727
    So far so good
    #33597
    • Replies 8,727
    Alas I noticed around 13:00 today access to the Forum was lost for around 10 minutes, CPU and RAM usage only reached 50%, so a little odd.
    IΒ  have disabled the cache plugin for now, to check if same issue happens tomorrow and apologies is website page load speed increases whilst cache is disabled.
    #33601
    Not slower now.
    #33602
    • Replies 8,727
    Viewing pages such as https://uktechhub.com/forums/Β  is the slowest, but good to know that you are not noticing the removal of cache / optimisations optionsΒ
    #33603
    Viewing above linke <3s, all fine on my side.
    #33611
    • Replies 8,727
    No issues with server performance today, so does seem as though the Caching option was causing the server to fail.
    #34040
    New problem first seen today.
    The exlamation mark of unseen posts doesn’t disappear after I see it and go back to “topic freshness” and reload the page.
    Only after some minutes it will disappear.
    #34043
    • Replies 8,727
    Thanks for letting me know and I will have a look at problem
    I did change a couple of the page caching options yesterday, so hopefully issue is that.
