› UKTH forums › UKTechHub News & Information › UKTechHub New Front Card Layout Improvements Forum Update: A Fresh New Look for the Front Page Over the past few weeks we’ve been making a number of improvements to the forum layout and navigation experience. The...
- This topic has 17 replies, 2 voices, and was last updated 1 month ago by
October 11, 2026 at 7:09 am #44308
Over the past few weeks we’ve been making a number of improvements to the forum layout and navigation experience. The forum homepage now features a cleaner ‘improved’ card-based design, improved spacing, clearer category separation, and a more modern appearance across desktop and mobile devices.
These changes are designed to make it easier to discover discussions, browse forum categories, and quickly find the latest activity. As always, this is still work in progress so please let us know what you think and report anything that doesn’t look quite right.
Thank you for helping make UKTechHub a better community for everyone.
October 11, 2026 at 8:37 am #44310Sorry, didnt realize any changes.
But the range to read postings is only about a forth of my 27″ monitor.
So titles and other things uses a lot to much space.
Even attachments could be much smaller.
Just my personal 2 cent about this topic.-
This reply was modified 1 month, 2 weeks ago by
Grisu.
Grisu.
October 11, 2026 at 11:14 am #44313Thank you, I will look into the spacing points you have made and see if I can make any adjustments
October 11, 2026 at 5:05 pm #44324You could eventually make title UK-TechHub and TechForum in one line which will give 2cm more for text on my monitor.
And under the menu, why does “active freshness” need 5 cm to the next line? 2cm would be more than enough with no space to the tabs above.
I’m not a designer, just spoken as technician.
Grisu.
October 11, 2026 at 5:55 pm #44326When you have time, could I ask you to screen shot (dump) an image of how your seeing “active freshness” as this would be most useful.
Also what screen resolution are you using with the 27″ monitor ?
October 11, 2026 at 9:52 pm #44331October 12, 2026 at 9:07 am #44349October 21, 2026 at 10:15 pm #44542October 22, 2026 at 7:02 am #44544. Grisu Said:Did you have no PHP-problems with the forum-SW?
Critical PHP Security Vulnerabilities (CVE-2026-109618 / CVE-2026-109619) – my Hosting provider has applied the recommended fix across all their servers and just in the process of checking whether this has had any adverse effects
October 22, 2026 at 8:57 am #44545October 22, 2026 at 10:02 am #44546October 22, 2026 at 5:13 pm #44548October 22, 2026 at 5:55 pm #44550Problems in the past with the forums like buttons have been associtated with DNS at users end
If you have time and the energy, try changing the DNS to your previous IP just to test, then if this works I can contact ‘Report a false positive to HaGeZi’ directly.
and / or
Email: support@hagezi.org
This reply was modified 1 month ago by
UK Sentinel. Reason: added addition note
October 23, 2026 at 7:10 am #44553Yes, has to do with it.
When I turn off DNS-filters, then it is showing the buttons like and dislike.I am using these filter lists:
https://hagezi-mirror.dnsbunker.org/wildcard/fake-onlydomains.txt
https://hagezi-mirror.dnsbunker.org/adblock/pro.txt
https://hagezi-mirror.dnsbunker.org/wildcard/tif-onlydomains.txt
https://gitlab.com/hagezi/mirror/-/raw/main/dns-blocklists/adblock/native.winoffice.txtYou need to login in order to vote
October 23, 2026 at 7:36 am #44554 -
