› UKTH forums › Wireless Routers & Modems › DrayTeK & Wireless › Vigor 2928 Firmware v5.4.1 Released – April 2026 DrayTek has officially rolled out Firmware v5.4.1 for the newly released Vigor 2928 series on April 8, 2026, bringing improved stability, enhanced security, and several refinements aimed at boosting overall...
- This topic has 0 replies, 1 voice, and was last updated 7 months, 3 weeks ago by
- April 11, 2026 at 8:33 pm #42390
DrayTek has officially rolled out Firmware v5.4.1 for the newly released Vigor 2928 series on April 8, 2026, bringing improved stability, enhanced security, and several refinements aimed at boosting overall router performance.
Vigor 2928 – Firmware Version 5.4.1 Release Notes
Release Date: 8 April 2026 Applicable Models: Vigor 2928 / 2928n / 2928ac (if applicable)
New Features
- Added system optimizations for the new Vigor 2928 hardware platform.
- Enhanced WAN load‑balancing logic for improved performance under heavy traffic.
- Introduced additional VPN compatibility improvements for third‑party clients.
Improvements
- Improved overall system stability during high‑throughput sessions.
- Refined DHCP handling to reduce rare cases of delayed IP assignment.
- Enhanced web interface responsiveness when applying configuration changes.
- Updated SSL/TLS components for better security and compatibility.
Fixes
- Fixed an issue where VPN tunnels could intermittently drop under specific conditions.
- Resolved a bug causing occasional UI freezes in the Diagnostics page.
- Corrected a problem where certain WAN failover events were not logged properly.
- Fixed minor firewall rule inconsistencies when importing older configuration files.
Known Notes
- A configuration backup is recommended before upgrading.
- Devices running early firmware versions may reboot twice during the update process — this is expected behavior.
https://www.draytek.com/support/latest-firmwares
