Zyxel USG FLEX H Series Firmware Update (uOS V1.39 Patch 0) – July 27, 2026 # Zyxel USG FLEX H Series Firmware Update: uOS V1.39 Patch 0 Released [July 27, 2026]   Zyxel Networks officially rolled out its latest firmware update, **uOS V1.39 Patch 0**,…
› UKTH forums › 🛜 Wireless Routers & Modems › Zyxel & Wireless › Zyxel USG FLEX H Series Firmware Update (uOS V1.39 Patch 0) – July 27, 2026 # Zyxel USG FLEX H Series Firmware Update: uOS V1.39 Patch 0 Released [July 27, 2026]   Zyxel Networks officially rolled out its latest firmware update, **uOS V1.39 Patch 0**,...
RELEASE
  • #43089
    Zyxel Networks officially rolled out its latest firmware update, **uOS V1.39 Patch 0**, on **July 27, 2026**.
    This release introduces critical security hardening, interface improvements, and performance optimizations. It applies directly to the next-generation USG FLEX H hardware family, including the **USG FLEX 100HP, 200H, 200HP, and 500H** firewall and gateway models.
    ### 📋 Main Changelog & Key Features (Released July 27, 2026)
    * **New Firmware Channel Selection:** Introducing a split upgrade track strategy. The “Stable” channel (Default) keeps production-ready devices on uOS 1.38 until further validation is completed. Switching to the “Latest” channel opens immediate access to newly deployed releases like V1.39.
    * **Cyber Resilience Act (CRA) Hardening:** FTP services are now **disabled by default** to minimize the out-of-the-box attack surface and comply with updated security audit requirements.
    * **Optimized IPS Engine Performance:** Bypasses deep packet inspection for trusted UDP traffic already identified by App Patrol, noticeably increasing throughput speeds.
    * **Nebula Identity Federation Enhancements:** Extended single sign-on support to cover both **Captive Portals** and **SSL VPN** tunnels.
    * **ACME Let’s Encrypt Integration:** Streamlined automation for deploying and renewing free SSL/TLS certificates directly from the local management interface.
    * **Local GUI Improvements:** Added support for cloning **App Patrol** profiles and introduced a real-time searchable dropdown menu for faster object selection.
    * **Nebula Centralized Logging:** Firmware upgrade activities are now fully tracked, timestamped, and pushed to Nebula cloud logs for audit transparency.
    ### 📦 Firmware Version Matrix (July 27, 2026 Release)
    | Model | Firmware Version | Release Date |
    | **USG FLEX 100HP** | V1.39(ACII.0)C0 | July 27, 2026 |
    | **USG FLEX 200H** | V1.39(ABWV.0)C0 | July 27, 2026 |
    | **USG FLEX 200HP** | V1.39(ABXE.0)C0 | July 27, 2026 |
    | **USG FLEX 500H** | V1.39(ABZH.0)C0 | July 27, 2026 |
    ### ⚠️ Deployment Notes & Best Practices
    * **Backup First:** Download a complete copy of your startup configuration (startup-config.conf) before initiating the upgrade process.
    * **Sequential Upgrades:** If your firewall is running an older baseline uOS version, check your current firmware topology. You may need to apply an intermediate version step first to safely migrate configuration structures.
    * **How to Apply:**
    * *Cloud Mode:* Navigate to **Site-wide > Configure > Firmware management > Firewall** in your Nebula Control Center.
    * *Standalone Mode:* Log into the local GUI and navigate to **Maintenance > Firmware/File Manager** to run a cloud firmware fetch or manually upload target binary packages.
    ### 🔗 Official Reference Links
    * **Full Change Notes:** Review the full breakdown over on the official [Zyxel Community Discussion Hub](https://community.zyxel.com/en/discussion/33654/usg-flex-h-series-v1-39-patch-0-firmware-release).
    * **Manual Downloads:** Pull localized binaries directly via the global [Zyxel Download Library](https://www.zyxel.com/global/en/support/download).
