ASUS DSL-AX82U recommended?
› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS DSL-AX82U recommended?
Viewing 15 posts - 16 through 30 (of 34 total)
  • #18585
    AvatarNessuno
    • Replies 11
    È stato rilasciato, versione 3.0.0.4.386_48378
    2022/04/07:
    Security Fixes and Improvements:
    – Fixed ZDI-CAN-16036.
    – Fixed lighttpd may execute any command.
    – Update OpenSSL to 1.1.1n for CVE-2022-0778.
    – Fixed HTTP smuggling issue of httpd.
    – Fixed arbitrary file reading vulnerability of httpd.
    – Fixed unauthorization DoS issue.
    – Fixed stack overflow issue of eapd.
    – Fixed string format stacks vulnerability, cross-site-scripting vulnerability and informational vulnerability. Thanks to Howard McGreehan.
    – Fixed authenticated stored XSS vulnerability. Thanks to Luke Walker – SmartDCC.
    – Fixed SQL injection vulnerability, json file traversal vulnerability, plc/port file traversal vulnerability, stack overflow vulnerability. Thanks to HP of Cyber Kunlun Lab.
    – Fixed LPD denial of service vulnerability, cfgserver heap overflow vulnerability, cfgserver denial of service vulnerability. Thanks to TianHe from BeFun Cyber Security Lab.
    – Fixed CVE-2015-9261, CVE-2017-15873, CVE-2021-28831, CVE-2021-34174.
    Bug Fixes and Improvements:
    – Fixed and enhanced AiMesh related issues.
    – Fixed and enhanced AiCloud related issues.
    – Fixed minor GUI bugs.
    – Fixed IPv6 related issues.
    – Fixed OpenVPN related issues.
    – Enhanced Fail-Back with Network Monitoring.
    – Fixed igmp snooping cannot enable/disable
    #18588
    Black Bird
    • Replies 146
    Thank you :)
    https://dlcdnets.asus.com/pub/ASUS/wireless/DSL-AX82U/FW_DSL_AX82U_300438648378.zip
    MD5: fa0dfc12186e7e4065a0c8336c19a964
    #18609
    [quote quote=18589]Thank you :)[/quote]
    Did this firmware release fix your IPv6 issues
    #18612
    AvatarEl3rt1cal
    • Replies 33
    This new firmware seems to be missing the ability to have multiple active VPN connections and route them, (or no VPN at all) to different lan-side client devices. from my perspective that was an unwelcome and unannounced downgrade and swiftly undone! On the plus side the SNR today + reset involved in FW upgrades got my line back to just 3kb below my maximum possible connection speed.
    #18614
    [quote quote=18612]and swiftly undone[/quote]
    That is not ideal, did you revert back to a previous version to get the multiple VPN’s working again ?
    #18615
    AvatarEl3rt1cal
    • Replies 33
    Yes I went back to 45660 which was the last version I could see. The only bug in that one that I mind is that after about 40-60 days the traffic analyser pages consistently stop working, which I guess could be memory related  or the way counting is implemented which corrupts what the GUI is trying to read as it is not related to the reported overall available memory.
    #18616
    Thanks for letting us know, I will pass back to ASUS the VPN query and see what they say
    #18643
    AvatarEl3rt1cal
    • Replies 33
    Thanks. It will be interesting to find out what they say. I see that in the notes they mentioned fixing OpenVPN issues, so I wonder if they knew the (single) VPN module worked with the DSL AX82u or was easier to base working  on to cure whatever problems there were, so they reverted to it.( I would also be interested in knowing what OpenVPN issues there were which were fixed (if they say), as I have never run into problems with OpenVPN and I use it routinely).
    In any event I sincerely hope Asus do ensure the multiple VPN setup works in future firmware for the DSL- AX82u as the ability to choose different VPN’s (or none) for different LAN-Side devices is a key feature for me now, but I would also prefer firmware that was up to date in terms of avoiding vulnerabilities.
    #18647
    Indeed, any chance of having a screen dump of your VPN settings with multiple VPN’s configured etc, just so I can reference this to ASUS .
    Obviously bloch out any sensitive details
    #18648
    Black Bird
    • Replies 146
    [quote quote=18609]
    Thank you :)
    Did this firmware release fix your IPv6 issues [/quote]
    The problem persists, it only works properly with the “passthrough” option.
    #18651
    Really!!!!  can you send a feedback form (like before) and put in comments box ‘UK Sentinel’ and explain issues with IPv6 again
    And then copy what you send to ASUS in this forum also
    #18652
    Black Bird
    • Replies 146
    [quote quote=18651]Really!!!! can you send a feedback form (like before) and put in comments box ‘UK Sentinel’ and explain issues with IPv6 again
    And then copy what you send to ASUS in this forum also [/quote]
    I sent a feedback
    [quote]Hi,
    Ipv6 does not work on connected devices. The ipv6 ping test from the modem interface is successful and cannot output despite ipv6 assignment to connected devices. I can only run it with the “passthrough” option.
    This feedback was made with the recommendation of ‘UK Sentinel’.[/quote]
    #18653
    Perfect
    #18666
    Black Bird
    • Replies 146
    [quote quote=18653]Perfect [/quote]
    The developer said that the ISP I am using does not support DHCP-PD and that is why I should use Passthrough.
