› UKTH forums › 🛜 Wireless Routers & Modems › ASUS & Wireless › ASUS GT-AX11000 Beta Firmware
- This topic has 11 replies, 3 voices, and was last updated 7 years, 8 months ago by
February 12, 2019 at 11:50 am #2190
I have from ASUS been given this latest beta firmware for the GT-AX11000 to share.
No changelog etc, but hopefully addresses a few of the main issues currently associated with the ASUS GT-AX11000
Usual UKTechHub.com Beta Firmware Policy applies (top of forum)
GT-AX11000_9.0.0.4_384_5781-g59be799_cferom_ubi.w
https://www.asuswebstorage.com/navigate/a/#/s/CC763129362D43289403814E0DA2C0D6Y
February 15, 2019 at 10:27 am #2229Thanks for sharing.
I’ve two issues in QoS:
in Adaptive QoS, bufferbloat is very high (>80ms)
in traditional Qos, download bandwidth limiter not work.
February 15, 2019 at 12:48 pm #2230[quote quote=2229]Thanks for sharing. I’ve two issues in QoS: in Adaptive QoS, bufferbloat is very high (>80ms) in traditional Qos, download bandwidth limiter not work.[/quote]
Thanks for update on findings, I will pass this information back to ASUS for their reference ;-)
February 15, 2019 at 4:06 pm #2233After a further reset of the device, traditional qos now works regularly, while the problem of adaptive qos remains (problem already present by some firmware releases).
In addition I can not connect rt-ax88u as aimesh nodeYou need to login in order to vote
February 15, 2019 at 7:01 pm #2236[quote quote=2233]After a further reset of the device, traditional qos now works regularly, while the problem of adaptive qos remains (problem already present by some firmware releases). In addition I can not connect rt-ax88u as aimesh node[/quote]
Did AiMesh work previously? if so then that is unlucky,
Such fun!
February 16, 2019 at 11:07 am #2237February 20, 2019 at 1:06 pm #2265Hello is there the newest beta Firmware for this Router?
The last Firmware was from 22. Nov. 2018.
But there time to time an issue with Login Devices to Wirless…
From 10 Logins go 1 failed. :/
And the firmware is lags.
I need the energy saver process for 2,4Ghz Wirless. I cant deactivated this.
In my older Asus AC87U i can deactivated the 2,4Ghz Wirless. It was perfekt for my Bluetooth mouse and Keyboard works perfekt.
February 20, 2019 at 3:22 pm #2266The only firmware I have is GT-AX11000_9.0.0.4_384_5781-g59be799_cferom_ubi.w
Nothing newer at present and is a little buggy ;)
February 20, 2019 at 3:56 pm #2267Ok thank you for your info :) gives there an Homepage with betafirmwarebuilds of this or other routermodels from asus?
Greet
February 20, 2019 at 4:16 pm #2268February 20, 2019 at 5:25 pm #2269So many manufactures has an inofficial homepage for betabuilds. In example by HTC ist this HTC.Dev Homepage with any updates for the HTC Phones and by asus i am can not find there.
Greet
February 20, 2019 at 5:46 pm #2270I understand, for ASUS routers, they (ASUS) have a different business model to others manufacturers for distribution of beta firmwares, For DSL beta’s and some RT routers, I am supplied beta Firmware for sharing from ASUS.
On some ASUS Routers, there is an option to automatically install beta Firmware’s, but as far as I am aware, no beta Firmware’s are available by Homepage etc.
Other site that have dedicated ASUS RT beta firmware’s is SNB Forum (https://www.snbforums.com)
Have a look at https://www.snbforums.com and hopefully you might find what you are looking for ?
